[Spreadsheet] Merge not availaible with ctrl selection
dsi-lille
Post by dsi-lille » Mon Apr 24, 2017 1:02 pm
if you select multiples cells with CTRL, the merge functionality is not available : icon is not clickable.
is it a normal behavior ?
Thanks for your answer,
Yoann.
Re: [Spreadsheet] Merge not availaible with ctrl selection
Post by Maxim » Tue Apr 25, 2017 7:15 am
Hello Yoann!
Yes, it's normal behavior. Why so? You cannot merge multiples cells in different positions.
dsi-lille
Post by dsi-lille » Tue Apr 25, 2017 7:55 am
Off course, i should be more accurate !
Some of our user seems to select the cells that they want to merge with CTRL and not with SHIFT or with the cursor.
Thanks again,
Yoann
Post by Maxim » Tue Apr 25, 2017 11:11 am
Yoann!
Multiselective option (function) will be added next release!
dsi-lille
Post by dsi-lille » Wed Apr 26, 2017 11:45 am
Great !
Thanks a lot Maxim !
Yoann.
Post by Maxim » Wed Apr 26, 2017 12:36 pm
You're always welcome!
dsi-lille
Post by dsi-lille » Fri May 18, 2018 1:47 pm
Hello Maxim,
When we select mutiples cells next to each other with CTRL, the merge functionality is still not available :
any news ?
Thanks,
Yoann
Post by Carl » Sat Jun 09, 2018 10:26 am
Hello Yoann,
This bug has been detected by our team. However, we are still working on fixing it. Please accept our apologies for the inconvenience.
As for now, you can merge cells selected with mouse-dragging.
dsi-lille
Post by dsi-lille » Mon Jun 11, 2018 6:08 am
Hello Carl,
no problem :)
Thanks for your answer !
Yoann.
