Password Protected Documents
Re: Password Protected Documents
Post by Carl » Fri Jun 15, 2018 7:15 am
Hello jsfrerot,
Unfortunately, the document server still isn't able to save passwords in documents. We have plans of fixing the issue, but cannot tell you the exact release date.
nikolayhg
Post by nikolayhg » Tue Dec 25, 2018 10:35 am
I use the Desktop Linux version with "end to end encryption" enabled. I created a document with my Desktop version and uploaded it in my onlyoffice cloud account in the browser. But when I try to open the file in the browser, it asks me for a password. What password should I enter, so that I can open the document in the browser?
Post by Maxim » Thu Dec 27, 2018 9:42 am
Hello nikolayhg!
There is no way! This is the point of using "end to end encryption" option.
nikolayhg
Post by nikolayhg » Thu Dec 27, 2018 1:16 pm
Thanks Maxim, few more questions:
1) does this mean that I can use the created document only with the Desktop Version of OnlyOffice?
2) Can I open the encrypted document with another client, like LibreOffice?
3) As the owner of my private key, can I generate the password needed to open the document?
Post by Maxim » Sat Dec 29, 2018 8:56 am
Hello nikolayhg!
Yes. Security of the document is the main reason which leads to use Onlyoffice Desktop Editor.
No, you cannot.
As i know you cannot generate the password
nikolayhg
Post by nikolayhg » Sat Dec 29, 2018 2:18 pm
Thank you for the answers, Maxim!
4) Is the password generated exclusively from information/data that only the user knows or has access to? (e.g. private key, hashes of the desired document, etc)
5) Is the source code for the generation of the password open source? And if yes, could you send me a link to it?
Post by Maxim » Thu Jan 10, 2019 7:16 am
Hello nikolayhg!
I do not know how the password is generated.
It is not open source code.
werner.meier
Post by werner.meier » Sun Oct 06, 2019 10:00 am
Is there any other possibility to make a document "READ-ONlY" ?
