Android documents version: ssl handshake problem
Suggestions on website/support/API etc.
cassielvandisse
Post by cassielvandisse » Tue Sep 22, 2020 12:32 pm
Hi, i contact you for a problem in android onlyoffice documents:
when i try to connect to webdav server (correctly cofigured serverside) the client documents on android wont connect with this error:
"handshake SSL error".
The sarver has valid SSL certificate from Let's Encrypt.
I try with the ios version too and correctly connected via webdav.
Some spec:
webdav on synology ds218play
last version of Onlyoffice Documents on android.
Please correct this issue,
Best regrads,
Cassielvandisse.
Re: Android documents version: ssl handshake problem
Post by Carl » Fri Sep 25, 2020 7:46 am
Hello Cassielvandisse,
Please check the domain name of your portal here:
https://www.sslshopper.com/ssl-checker.html
Perhaps, intermediate certificate is missing on the server.
Also try to add #ssloff to the address of the portal and check if the connection is possible: https://example.com/#ssloff
