Hi everybody,
1) Visible Behaviour
I have a onlyoffice Community Edition - installed via docker. The Version is 10.0.4.1001.
I added a IMAP-Account to the Mail modul of onlyoffice and I can read my emails and I can write emails.
As soon as I want to use the function "export to CRM" there is an error message. I attached two screenshots.
The error message is german but this should be a good translation:
The selected item is no longer available or the connection has been lost. Please check the location of the selected CRM element and your network connection. if the error persists, please contact your portal administrator.
2) Logs
In the logs (/app/onlyoffice/CommunityServer/logs/web.sql.log) I found this error messages:
2019-12-02 10:00:26,992|95|0.6356|Connection.Open||
2019-12-02 10:00:26,992|95|0.8161|Command.ExecuteScalar|select value from core_settings where tenant = @p0 and id = @p1|@p0=-1, @p1=BaseDomain
2019-12-02 10:00:26,996|95|1.858|Command.ExecuteReader(Default)|select t.id, t.alias, t.mappeddomain, t.version, t.version_changed, t.name, t.language, t.timezone, t.owner_id, t.trusteddomains, t.trusteddomainsenabled, t.creationdatetime, t.status, t.statuschanged, t.payment_id, t.last_modified, p.partner_id, p.affiliate_id, p.campaign, t.industry, t.spam, t.calls from tenants_tenants t left outer join tenants_partners p on t.id = p.tenant_id where alias = @p0 or mappeddomain = @p1|@p0=office.MYMAILADRESS, @p1=office.MYMAILADRESS
2019-12-02 10:00:26,996|95|1.96|Command.ExecuteReader(Default)|select t.id, t.alias, t.mappeddomain, t.version, t.version_changed, t.name, t.language, t.timezone, t.owner_id, t.trusteddomains, t.trusteddomainsenabled, t.creationdatetime, t.status, t.statuschanged, t.payment_id, t.last_modified, p.partner_id, p.affiliate_id, p.campaign, t.industry, t.spam, t.calls from tenants_tenants t left outer join tenants_partners p on t.id = p.tenant_id|
2019-12-02 10:00:27,023|95|1.5776|Connection.Open||
2019-12-02 10:00:27,023|95|1.9029|Command.ExecuteReader(Default)|select id, first_name, last_name, company_name, title, notes, is_company, industry, status_id, company_id, create_on, create_by, display_name, is_shared, contact_type_id, currency from crm_contact use index (company_id) where tenant_id = @p0 and id = @p1|@p0=1, @p1=17
2019-12-02 10:00:27,027|95|0.6541|Connection.Open||
2019-12-02 10:00:27,027|95|2.2498|Command.ExecuteReader(Default)|select id, id_mailbox, id_user, tenant, address, uidl, md5, from_text, to_text, reply_to, cc, bcc, subject, introduction, importance, date_received, date_sent, size, attachments_count, unread, is_answered, is_forwarded, stream, folder, folder_restore, spam, is_removed, time_modified, mime_message_id, mime_in_reply_to, chain_id, chain_date, is_text_body_only, has_parse_error, calendar_uid from mail_mail where tenant = @p0 and id_user = @p1 and id = @p2|@p0=1, @p1=5e0b......, @p2=382
2019-12-02 10:00:27,033|95|2.6661|Command.ExecuteReader(Default)|select mm.id, mm.from_text, mm.to_text, mm.cc, mm.reply_to, mm.subject, mm.importance, mm.date_sent, mm.size, mm.attachments_count, mm.unread, mm.is_answered, mm.is_forwarded, (SELECT CAST(group_concat(tm.id_tag ORDER BY tm.time_created SEPARATOR ',') AS CHAR) from mail_tag_mail as tm WHERE tm.id_mail = mm.id) tagIds, mm.folder_restore, mm.folder, mm.chain_id, mm.chain_date, mm.id_mailbox, mm.calendar_uid, mm.stream, mm.uidl, mm.is_removed from mail_mail mm where mm.tenant = @p0 and mm.id_user = @p1 and mm.is_removed = @p2 and mm.chain_id = @p3|@p0=1, @p1=5e0b......, @p2=False, @p3=984f044bb86b6....
2019-12-02 10:00:27,053|95|19.293|Connection.Open||
2019-12-02 10:00:27,057|95|3.3912|Command.ExecuteReader(Default)|select id, id_mailbox, id_user, tenant, address, uidl, md5, from_text, to_text, reply_to, cc, bcc, subject, introduction, importance, date_received, date_sent, size, attachments_count, unread, is_answered, is_forwarded, stream, folder, folder_restore, spam, is_removed, time_modified, mime_message_id, mime_in_reply_to, chain_id, chain_date, is_text_body_only, has_parse_error, calendar_uid from mail_mail where is_removed = @p0 and tenant = @p1 and id_user = @p2 and id = @p3|@p0=False, @p1=1, @p2=5e0bc5f7-341f-49e9-b698-a77f682dd24c, @p3=382
2019-12-02 10:00:27,058|95|0.9764|Command.ExecuteReader(Default)|select id_tag from mail_tag_mail where tenant = @p0 and id_user = @p1 and id_mail = @p2|@p0=1, @p1=5e0bc5f7-341f-49e9-b698-a77f682dd24c, @p2=382
2019-12-02 10:00:27,058|95|1.2539|Command.ExecuteReader(Default)|select mail_attachment.id, mail_attachment.id_mail, mail_attachment.name, mail_attachment.stored_name, mail_attachment.type, mail_attachment.size, mail_attachment.need_remove, mail_attachment.file_number, mail_attachment.content_id, mail_attachment.tenant, mail_attachment.id_mailbox, mail_mail.stream, mail_mail.id_user from mail_attachment mail_attachment inner join mail_mail mail_mail on mail_mail.id = mail_attachment.id_mail where mail_attachment.need_remove = @p0 and mail_attachment.tenant = @p1 and mail_mail.id_user = @p2 and mail_attachment.id_mail = @p3 and mail_attachment.content_id is null|@p0=False, @p1=1, @p2=5e0b.., @p3=382
2019-12-02 10:00:27,138|95|0.026|Connection.Dispose||
2019-12-02 10:00:27,138|95|0.3439|Connection.BeginTransaction||
2019-12-02 10:00:27,138|95|0.4371|Command.ExecuteNonQuery|insert into mail_chain_x_crm_entity(id_chain,id_mailbox,id_tenant,entity_id,entity_type) values (@p0,@p1,@p2,@p3,@p4)|@p0=984f044bb86b66aeb1ce729ff.bb98a82deb.20191202091144.0a327acc99.a08cc85a@mail180.atl121.mcsv.net, @p1=2, @p2=1, @p3=17, @p4=1
2019-12-02 10:00:27,138|95|0.9106|Command.ExecuteReader(Default)|select u.id, u.username, u.firstname, u.lastname, u.sex, u.bithdate, u.status, u.title, u.workfromdate, u.terminateddate, u.contacts, u.email, u.location, u.notes, u.removed, u.last_modified, u.tenant, u.activation_status, u.culture, u.phone, u.phone_activation, u.sid, u.sso_name_id, u.sso_session_id, u.create_on from core_user u where tenant = @p0 and id = @p1|@p0=1, @p1=5e0bc5f7-341f-49e9-b698-a77f682dd24c
2019-12-02 10:00:27,138|95|0.3954|Command.ExecuteScalar|select pwdhashsha512 from core_usersecurity where tenant = @p0 and userid = @p1|@p0=1, @p1=5e0b...
2019-12-02 10:00:27,144|95|0.0487|Connection.Dispose||
2019-12-02 10:00:27,144|95|0.0389|Connection.Dispose||
2019-12-02 10:00:27,144|95|0.0005|Connection.Dispose||
2019-12-02 10:00:27,144|95|0.0155|Connection.Dispose||
Is this a bug or is there any kind of missconfiguration? The CRM Modul is just working fine.
Best regards
Christoph
Bug? OnlyOffice Mail: connect an email to CRM throws an error
- Attachments
- oo1.png (45.68 KiB) Viewed 879 times
- oo2.png (58.36 KiB) Viewed 879 times
Re: Bug? OnlyOffice Mail: connect an email to CRM throws an error
Hello Christoph,
Please check if the logs web.log, web.api.log, web.api-system.log contain any error messages.
Also reproduce the issue with the browser console open and check if there are any errors in Network and Console tabs.
Hey Carl,
1) browser console:
the error in the chrome browser console is: (I replaced the domain with <DOMAIN> and it is ok, that onlyoffice uses port 444)
head-nQxa-URZKVp3Np88-2nT5A2.js?ver=10.0.4.1001:2
PUT https://office.<DOMAIN>.de:444/api/2.0/mail/conversations/crm/link.json?__=239646 500 (Server error)
If I try to open the api-link there is a not found page from onlyoffice "Sorry, the resource cannot be found."
2) logs
give me some seconds. I will check the logs you mentioned.
Best regards
Christoph
1) browser console:
2) logs
Best regards
Christoph
Hey Carl,
here are the logs
1) web.api.log
at System.Net.WebConnection.Connect (System.Net.WebOperation operation, System.Threading.CancellationToken cancellationToken) [0x0019b] in <2703bbaa0a6e4686b6033c2dddb1a363>:0
at System.Net.WebConnection.Connect (System.Net.WebOperation operation, System.Threading.CancellationToken cancellationToken) [0x00217] in <2703bbaa0a6e4686b6033c2dddb1a363>:0
at System.Net.WebConnection.InitConnection (System.Net.WebOperation operation, System.Threading.CancellationToken cancellationToken) [0x000cc] in <2703bbaa0a6e4686b6033c2dddb1a363>:0
at System.Net.WebOperation.Run () [0x0009a] in <2703bbaa0a6e4686b6033c2dddb1a363>:0
at System.Net.WebCompletionSource`1[T].WaitForCompletion () [0x00094] in <2703bbaa0a6e4686b6033c2dddb1a363>:0
at System.Net.HttpWebRequest.GetRequestStream () [0x00016] in <2703bbaa0a6e4686b6033c2dddb1a363>:0
at RestSharp.Http.WriteRequestBody (System.Net.HttpWebRequest webRequest) [0x0002b] in <7a49fa7fd4d24c9bb5deb1f5c33e29c9>:0
at RestSharp.Http.PostPutInternal (System.String method) [0x00017] in <7a49fa7fd4d24c9bb5deb1f5c33e29c9>:0
at RestSharp.Http.AsPost (System.String httpMethod) [0x00008] in <7a49fa7fd4d24c9bb5deb1f5c33e29c9>:0
at RestSharp.RestClient.DoExecuteAsPost (RestSharp.IHttp http, System.String method) [0x00001] in <7a49fa7fd4d24c9bb5deb1f5c33e29c9>:0
at RestSharp.RestClient.Execute (RestSharp.IRestRequest request, System.String httpMethod, System.Func`3[T1,T2,TResult] getResponse) [0x00026] in <7a49fa7fd4d24c9bb5deb1f5c33e29c9>:0
at ASC.Mail.Utils.ApiHelper.Execute (RestSharp.RestRequest request) [0x00091] in <706486a74e4747038c44ad92fa877bda>:0
at ASC.Mail.Utils.ApiHelper.AddToCrmHistory (ASC.Mail.Data.Contracts.MailMessageData message, ASC.Mail.Data.Contracts.CrmContactData entity, System.Collections.Generic.IEnumerable`1[T] fileIds) [0x00135] in <706486a74e4747038c44ad92fa877bda>:0
at ASC.Mail.Core.Engine.CrmLinkEngine.AddRelationshipEvents (ASC.Mail.Data.Contracts.MailMessageData message, System.String httpContextScheme) [0x00192] in <706486a74e4747038c44ad92fa877bda>:0
at ASC.Mail.Core.Engine.CrmLinkEngine.LinkChainToCrm (System.Int32 messageId, System.Collections.Generic.List`1[T] contactIds, System.String httpContextScheme) [0x0022f] in <706486a74e4747038c44ad92fa877bda>:0
at ASC.Api.Mail.MailApi.LinkConversationToCrm (System.Int32 id_message, System.Collections.Generic.IEnumerable`1[T] crm_contact_ids) [0x0005c] in <05cc20bcdf3340ecac949d3f10e8776b>:0
at (wrapper managed-to-native) System.Reflection.RuntimeMethodInfo.InternalInvoke(System.Reflection.RuntimeMethodInfo,object,object[],System.Exception&)
at System.Reflection.RuntimeMethodInfo.Invoke (System.Object obj, System.Reflection.BindingFlags invokeAttr, System.Reflection.Binder binder, System.Object[] parameters, System.Globalization.CultureInfo culture) [0x0006a] in <285579f54af44a2ca048dad6be20e190>:0
web.log)
no entries at the moment of the error
web.api-system.log)
there is no such file on the system.
Best regards
Christoph
here are the logs
1) web.api.log
web.log)
web.api-system.log)
Best regards
Christoph
