Confluence Plugin
MIK
Confluence Plugin
Post by MIK » Mon Sep 02, 2019 2:33 pm
Hi there
In our company we have a Confluence Server and I've set up an onlyoffice community server for integration in confluence.
With the Confluence-App "ONLYOFFICE Connector for Confluence" we can edit documents pretty good.
But our problem is, that when we edit a document, it saves the progress on the onlyoffice, but if I use one of the other buttons ("preview", "edit in Excel 20XX"), the changes that I did in onlyoffice doesn't save for for the other options.
I know we could just use the onlyoffice and ignore the other options, but a preview is sometimes also very helpful if you just want to have a quick look at a data sheet.
Does anybody have a solution to this?
kind regards
MIK
Re: Confluence Plugin
Post by Carl » Thu Sep 12, 2019 7:26 am
Hello MIK,
Could you please provide a more detailed description of the issue?
1. Version of Document Server.
2. Version of Confluence.
3. Version of the connector app.
4. Step-by-step scenario of reproducing the issue.
