Can't access service on browser
micaldas
Post by micaldas » Mon Apr 08, 2019 6:06 pm
I'm trying to install Onlyoffice Community Edition, without the mail server, on a Debian 10 vps.
I used the instructions on thew site to install without the mail-server and when I tried to access it by inputting my ip on the browser I got an error message saying that "The connection to the server was reset while the page was loading."
You can see the error page here https://i.ibb.co/MNGbmmD/IMG-20190408-185127.jpg
I've tried to install it with a different set of instructions (https://www.linuxbabe.com/linux-server/ ... untu-16-04), but i got the same result.
My firewall status is the following:
22/tcp (SSH)               ALLOW IN    Anywhere
80,443/tcp (WWW Full)      ALLOW IN    Anywhere
443                        ALLOW IN    Anywhere
5222                       ALLOW IN    Anywhere
9865                       ALLOW IN    Anywhere
9871                       ALLOW IN    Anywhere
9888                       ALLOW IN    Anywhere
25                         ALLOW IN    Anywhere
5280                       ALLOW IN    Anywhere
9866                       ALLOW IN    Anywhere
9882                       ALLOW IN    Anywhere
22/tcp (SSH (v6))          ALLOW IN    Anywhere (v6)
80,443/tcp (WWW Full (v6)) ALLOW IN    Anywhere (v6)
443 (v6)                   ALLOW IN    Anywhere (v6)
5222 (v6)                  ALLOW IN    Anywhere (v6)
9865 (v6)                  ALLOW IN    Anywhere (v6)
9871 (v6)                  ALLOW IN    Anywhere (v6)
9888 (v6)                  ALLOW IN    Anywhere (v6)
25 (v6)                    ALLOW IN    Anywhere (v6)
5280 (v6)                  ALLOW IN    Anywhere (v6)
9866 (v6)                  ALLOW IN    Anywhere (v6)
9882 (v6)                  ALLOW IN    Anywhere (v6)
25                         ALLOW OUT   Anywhere
110                        ALLOW OUT   Anywhere
143                        ALLOW OUT   Anywhere
465                        ALLOW OUT   Anywhere
993                        ALLOW OUT   Anywhere
995                        ALLOW OUT   Anywhere
25 (v6)                    ALLOW OUT   Anywhere (v6)
110 (v6)                   ALLOW OUT   Anywhere (v6)
143 (v6)                   ALLOW OUT   Anywhere (v6)
465 (v6)                   ALLOW OUT   Anywhere (v6)
993 (v6)                   ALLOW OUT   Anywhere (v6)
995 (v6)                   ALLOW OUT   Anywhere (v6)
Any help would be greatly appreciated.
Re: Can't access service on browser
Post by Carl » Wed Apr 10, 2019 8:10 am
Have you installed the Community Edition in Docker? Please run the command docker ps and check if the containers are running.
We strongly recommend to use our instruction to install the product:
