Upgrading to 18.10.255
Re: Upgrading to 18.10.255
Post by Maxim » Thu Jul 25, 2019 10:37 am
Hello koksalbasar!
Can you attach this file for analyze?
koksalbasar
Post by koksalbasar » Fri Jul 26, 2019 11:13 am
Hi Maxim,
If you're asking the office files these files are showing the pictures when you download to local computer. I attached one sample (Please check the post dated Fri Apr 26, 2019. I explained everything). But if you want to something else please explain me more.
08_1_NextSteps.zip
(187.79 KiB) Downloaded 24 times
Thanks for your efforts,
KB
koksalbasar
Post by koksalbasar » Thu Aug 01, 2019 10:37 am
Hi Maxim,
I tried to mobile and desktop applications. But the result is the same. I could not find any other information about this issue.
When I copy the same document from my server to local disk and open with OnlyOffice Desktop application the pictures are available. Can it be a security problem? Because the files are not corrupted.
Thanks for your support,
KB
KB
Post by Maxim » Sun Aug 04, 2019 2:39 pm
Hello koksalbasar!
I am sure that there is a problem in your server. The file is not corrupted. Is there installed antivirus or firewall on your Windows?
koksalbasar
Post by koksalbasar » Thu Aug 08, 2019 11:25 am
Hi Maxim,
Windows Defender and Windows Firewall is active in my server. What do you suggest me?
KB
KB
Post by Maxim » Thu Aug 08, 2019 7:58 pm
Hello koksalbasar!
I would suggest you to check this out by disabling Windows Defender and Windows Firewall for a short time and try to repeat your actions just to be sure that Windows Defender and Windows Firewallare not connected with this issue.
koksalbasar
Post by koksalbasar » Thu Aug 15, 2019 12:33 pm
Hi Maxim,
I've a good news this time. PDF is ok and document's image problem is solved, after I stopped the firewall and defender services.
I want to share with you very interesting case both of them PDF and document's image issues are not continue any more when restart the firewall and defender services.
I did not changed any configuration both of them. Many time I restarted my server but the restarts didn't solve my problem before. Maybe the problem is releated to service starting sequence.
Anyway thanks for your support. I hope the problem will not rise from dead.
All my best wishes,
Köksal BAŞAR
KB
Post by Carl » Thu Sep 12, 2019 7:23 am
Hi Köksal,
We are glad the issue has been resolved.
