Upgrading to 18.10.255
koksalbasar
Post by koksalbasar » Thu Mar 28, 2019 12:26 pm
I'm planning to upgrade my Community Edition version to 18.10.255 from 18.04.200 (because pdf files are not shown). But I cannot find any information above version 9.
Could you please suggest me some documentation for this upgrade?
Thanks for your support,
KB
Köksal BAŞAR
Re: Upgrading to 18.10.255
Post by Carl » Wed Apr 10, 2019 12:12 pm
On Windows, components of ONLYOFFICE Community Edition (Community Server and Document Server) can be installed over the existing installation. New versions can be downloaded here:
Document Server
Community Server
Or you can also run the Community Edition installer, it will do the same - remove the current versions of components and install the new ones.
koksalbasar
Post by koksalbasar » Wed Apr 24, 2019 11:51 am
Thank you for your response.
I used the community edition installation file (ONLYOFFICE_Community_Edition_Win-install.v18.10.255.exe) for the upgrade.
The upgrade is completed without a problem. But my problems still continue.
The documents are not shown correctly.
* The images/pictures in the Office documents are showing as a red rectangle with x inside of it. The texts and fonts are correct.
* The pdf files cant readable. No images or no texts are showing.
If I download these files to local disk they are readable without a problem.
In this situation, we can't use OnlyOffice better than a private Gdrive functionality.
I can't find any information on the forum. Could you please show me a way to understand the problem and solve them.
Thank for your support,
KB
Köksal BAŞAR
Post by Carl » Wed Apr 24, 2019 1:19 pm
What are the currently installed versions of ONLYOFFICE components? (Community and Document Servers)
koksalbasar
Post by koksalbasar » Wed Apr 24, 2019 2:56 pm
Hi Carl,
I installed from this file ONLYOFFICE_Community_Edition_Win-install.v18.10.255.exe.
In addition, when I checked out "About this program" the version is 9.6.632
Is there any location to check the number?
Thanks
KB
Köksal BAŞAR
Post by Carl » Fri Apr 26, 2019 12:16 pm
You can check the version numbers in Windows Control Panel. BTW, we have just released new Community Server 10.0, I'd recommend you to use an updated installer:
https://sourceforge.net/projects/teamla ... e/download
koksalbasar
Post by koksalbasar » Fri Apr 26, 2019 8:07 pm
I installed the file you suggested. The office documents still have a red rectangle with X and the pictures don't appear. I added a sample page pictures.
PDF files were blank on the screen before the new installation and they give the following error after installation.
Connection is lost. You can still view the document, but will not be able to download or print until the connection restored.
The document service configuration as follows.
Document Editing Service Address : /ds-vpath/
Document Service address for requests from the Community Server : http://localhost:8083/
Community Server address for requests from the Document Service : http://localhost/
I can't be sure what I'm doing wrong. If there is any log file I want to share with you if you give me the file location.
KB
Köksal BAŞAR
koksalbasar
Post by koksalbasar » Wed Jun 19, 2019 9:48 am
Hi everybody,
Can anybody answer me about this issue?
Thank you,
KB
Köksal BAŞAR
Post by Maxim » Thu Jun 20, 2019 7:04 am
Hello koksalbasar!
Did you upgrade your Community Edition?
What is installed version of the Community Edition?
koksalbasar
Post by koksalbasar » Wed Jul 24, 2019 5:55 pm
Hi Maxim,
I finished to installing ONLYOFFICE_CommunityEdition_Win-install.v19.05.346.exe just now. Nothing is changed. There is no picture on the documents.
Is this a only issue about this subject?
I really don't know what will I do. Can a fresh install work for me? (May the following link helps me for this issue? https://helpcenter.onlyoffice.com/serve ... ndows.aspx)
This is so important for us because if it'll work we're planning to buy (I don't know which licence fit for us) before end of 2019.
KB
Köksal BAŞAR
