How could I surpass the limitation to 20 simultaneous connections?
Locked
Hacktivista
Post by Hacktivista » Wed Mar 27, 2019 10:57 am
I'd like to provide the suite for free to end users, but 20 simultaneous connections could quickly reach its limitations. How could I surpass this limitation?
Re: How could I surpass the limitation to 20 simultaneous connections?
Post by Carl » Fri Mar 29, 2019 1:37 pm
20 simultaneous connections is a limitation of free ONLYOFFICE Community Edition. It cannot be increased. If you want more connections, you can purchase the commercial solution ONLYOFFICE Enterprise Edition.
quentind
Post by quentind » Wed Sep 04, 2019 11:42 am
Hello !
Did you manage to increase the 20 limitations ?
I think to build the code with this tutorial (https://helpcenter.onlyoffice.com/serve ... -code.aspx) with changing the good variable that check this 20 limitations.
Andrew
Post by Andrew » Mon Sep 09, 2019 8:38 am
Once again I want to remind you that 20 simultaneous connections is a limitation of free ONLYOFFICE Community Edition. Discussions on how to bypass limitation is forbidden at this forum, please, be respectful to it.
Locked
