OnlyOffice Integration not working
bkpfast
Post by bkpfast » Thu Aug 02, 2018 7:52 am
we are evaluating Nextcloud and are comparing it with OneDrive für Business.
For Office (collaboration not necessary) we would like to use OnlyOffice Integration Server On Premise – no public cloud services.
At the moment we are running Nextcloud on Ubuntu Server18.04.1 LTS:
We secured it with certificates signed by our own PKI –works without any problems.
Now we installed OnlyOffice Integration Server on Windows (Yeah, Yeah I know…);
this server alos got certificates signed by our PKI – works (test page…).
The issue is that Nextcloud works as if there were no OnlyOffice Plugin.
So when you open a doc or docx for example just the download dialogie pops up so that I can open the document with my local Office or save it to disk.
The welcome page works like a charme
But when I try to configure the connector it does not work.
For our OnlyOffice Integration config please see attached screenshot.
When I click „save“ long time nothing happens.
Nextcloud log says: „
Error onlyoffice CommandRequest on check error: Bad Request oder Timeout Fehlermeldung 2018-08-01T15:05:43+0200
Error PHP file_get_contents(https://onlyoffice.xxxxx.xxxxx.de/coaut ... rvice.ashx): failed to open stream: HTTP request failed! At var/www/html/nextcloud/apps/onlyoffice/lib/documentservice.php#351
OnlyOffice Out_Log says:
2018-08-01 16:04:47.535] [ERROR] nodeJS - [AMQP] Error: connect ECONNREFUSED 127.0.0.1:5672
at Object.exports._errnoException (util.js:1020:11)
at exports._exceptionWithHostPort (util.js:1043:20
at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1086:14)
I tried hosts file, configuring Windows firewall, onlyoffice’=>array(‘verify_peer_off’=>true).
Until now it does not run
Help would be really appreciated.
Thanks in advance
Re: OnlyOffice Integration not working
Post by Maxim » Fri Aug 03, 2018 8:50 am
Hello bkpfast !
Do you get response from the Nextcloud to Document Server?
wget https://Document_Server/web-apps/apps/api/documents/api.js
bkpfast
Post by bkpfast » Mon Aug 06, 2018 8:39 am
Hello Maxim,
thank you very much fpr the answer!
When I use the short name of our OnlyOffice Server ist does not work (common name certificate issue).
But when using FQDN it works without problems, please see attached screenshot.
HTTP request sent, awaiting response... 200 OK
Length: 26779 (26K) [application/javascript]
Saving to: ‘api.js’
api.js 100%[========================================================================================================================================>] 26.15K --.-KB/s in 0s
2018-08-06 10:30:37 (103 MB/s) - ‘api.js’ saved [26779/26779]
Post by Maxim » Mon Aug 13, 2018 8:54 am
Hello bkpfast!
It means that Document Server is accessible for Nextcloud using FQDN.
Please check using "wget command" access to Nextcloud from Document Server.
bkpfast
Post by bkpfast » Tue Aug 14, 2018 11:51 am
Document server to Nextcloud server:
1. Shortname
C:\install\wget-1.19.4-win64>wget https://nextcloud/web-apps/apps/api/documents/api.js
--2018-08-13 15:07:39-- https://nextcloud/web-apps/apps/api/documents/api.js
Resolving nextcloud (nextcloud)... 10.XX.XX.XX
Connecting to nextcloud (nextcloud)|10.XX.XX.XX|:443... connected.
ERROR: cannot verify nextcloud's certificate, issued by 'CN=XXXXXX XXXXXXXXX PKI001,DC=XXXXXX,DC=XXXXXXXXX,DC=de':
Unable to locally verify the issuer's authority.
ERROR: no certificate subject alternative name matches
requested host name 'nextcloud'.
To connect to nextcloud insecurely, use `--no-check-certificate'.
2. FQDN
C:\install\wget-1.19.4-win64>wget https://nextcloud.XXXXXX.XXXXXXXXX.de/w ... nts/api.js
--2018-08-13 15:08:15-- https://nextcloud.XXXXXX.XXXXXXXXX.de/w ... nts/api.js
Resolving nextcloud.XXXXXX.XXXXXXXXX.de (nextcloud.XXXXXX.XXXXXXXXX.de)... 10.XX.XX.XX
Connecting to nextcloud.XXXXXX.XXXXXXXXX.de (nextcloud.XXXXXX.XXXXXXXXX.de)|10.XX.XXX.XX|:443... connected.
ERROR: cannot verify nextcloud.XXXXXX.XXXXXXXXX.de's certificate, issued by 'CN=XXXXXX XXXXXXXXX PKI001,DC=XXXXXX,DC=XXXXXXXXX,DC=de':
To connect to nextcloud.XXXXXX.XXXXXXXXX.de insecurely, use `--no-check-certificate'.
But next to OnlyOffice we do not have any issues with Nextcloud no matter what browser or tool (curl) we use.
Thanks in advance
/bkpfast
Post by Maxim » Mon Aug 20, 2018 1:14 pm
Hello bkpfast!
Please add intermediate certs (chain certs)
bkpfast
Post by bkpfast » Tue Aug 21, 2018 2:30 pm
Thanky You very much.
Where (config file...) should I add intermediate what (Neytcloud server , Onlyoffice server) intermediate certificates?
Thanks in advance!
regards
/bkpfast
Post by Maxim » Mon Aug 27, 2018 6:31 am
Hello bkpfast!
Please see here
