Integration with ReactJS
Abhishek_Nalin
Post by Abhishek_Nalin » Mon Mar 26, 2018 2:21 pm
I went through the integration example of NodeJS which was done using EJS. I was looking for a ReactJS example.
I have installed document server on IP - AA.BB.YY.XX and it is working fine.
We have a ReactJS frontend. I added the script tag in our index.html
<script type="text/javascript" src="http://AA.BB.YY.XX/web-apps/apps/api/do ... "></script>
When the user clicks on the word document in my app I call a function named openEditor and pass the url
openEditor = (url) => {
new DocsAPI.DocEditor("placeholder", {
"document": {
"fileType": "docx",
"key": "Khirz6zTPdfd7",
"url": url
"documentType": "text"
However this doesn't work because I get the compilation error 'DocsAPI' is not defined'
Is there a way to make this work? How do I define DocsAPI in my ReactComponent?
Is this the right way to integrate with React?
Regards
Abhishek
Re: Integration with ReactJS
Post by Maxim » Tue Apr 03, 2018 10:25 am
'DocsAPI' is not defined means that there is no access to API
what do you get if you go to http://AA.BB.YY.XX/web-apps/apps/api/documents/api.js?
BorisZR
Post by BorisZR » Thu Jun 28, 2018 12:29 pm
You have to use window explicity to access the DocsAPI object.
Code snippet:
import React, { Component } from 'react';
import './App.css';
class App extends Component {
  render() {
    return (
        <div id="placeholder"></div>
  componentDidMount() {
    let config = {
      "document": {
        "fileType": "docx",
        "key": "...",
        "title": "...",
        "url": "..."
      "documentType": "text",
      "editorConfig": {
        "callbackUrl": "..."
    new window.DocsAPI.DocEditor("placeholder", config);
export default App;
Best regards,
Boris
Srini
Post by Srini » Tue Sep 03, 2019 2:01 pm
Hi team,
I have installed DocumentServer and its dependencies by following below link steps
https://helpcenter.onlyoffice.com/serve ... -apps.aspx
I believe it will be installed in the default port 8080
When i use below in my React js application, it not working properly(says DocsAPI undefined). Can you please help me to sort this out?
<script type="text/javascript" src="http://localhost:8080/web-apps/apps/api ... "></script>
this.myWebViewer = new window.DocsAPI.DocEditor("placeholder", {"document": {
"fileType": "docx",
"url": "https://example.com/url-to-example-document.docx"
"editorConfig": {
"callbackUrl": "https://example.com/url-to-callback.ashx"
Post by Carl » Thu Sep 12, 2019 7:24 am
Hi Srini,
Your request has been replied to in our helpdesk.
React_dev
Post by React_dev » Tue Oct 22, 2019 3:14 pm
Hi Srini,
Where though?
Could you supply a link to the reply?
Post by Carl » Thu Oct 24, 2019 3:15 pm
Hello React_dev,
We don't post links to our Helpdesk threads here. These threads are private anyway, only our team and users who submit the tickets have access to them. If you have any questions, please post them here.
