unable add mail account
toaoman
Post by toaoman » Fri Nov 10, 2017 12:06 pm
hello,everyone,
Install OnlyOffice with script :
- wget http://download.onlyoffice.com/install/ ... install.sh
- bash opensource-install.sh -md "yourdomain.com"
Install finish.
I successful finish add domain name
add domain ok.jpg (119.73 KiB) Viewed 2901 times
but when I slect mail,set up the first account
add account.jpg (143.83 KiB) Viewed 2901 times
report a error "Account connection error..... Unknown mail provider settings."
why?
Re: unable add mail account
Post by Maxim » Fri Nov 10, 2017 12:52 pm
you cannot add mailbox to the your mail domain? you should create mailbox first of all. Where (or how) did you create mailbox?
toaoman
Post by toaoman » Fri Nov 10, 2017 2:49 pm
Maxim wrote:Hello!
I use Administrator user login,when I at settings---mail server--- add new mailbox, i cannot select all,because i cannot found select all has checkbox.
no checkbox.jpg (41.74 KiB) Viewed 2896 times
I found only Administrator can create new mailbox for every register user.
But every new register cannot create mailbox for themself.
toaoman
Post by toaoman » Fri Nov 10, 2017 3:52 pm
I found some wrong at Mail Service page.
Connect Mail Server IP error,but i alreay install onlyoffice-mail-server use docker
Maybe system provide default user name,and database password is wrong.
What is correct user name and password?
Post by Maxim » Sat Nov 11, 2017 9:28 am
Hello toaoman!
Please read attentively what is written!
"This option allows to connect your portal to the Mail Server installed on a remote computer using the Docker installation.
Note: make sure that ports 3306 and 8081 are opened at the computer where Mail Server is installed. We also strongly recommend that you change your Mail Server database access password."
Of course, Administrator is responsible to create mailboxes only.
toaoman
Post by toaoman » Sat Nov 11, 2017 10:21 am
Maxim wrote:Hello toaoman!
I also attention that need open port 3306 and 8081.
But how to do this?
Post by Maxim » Fri Nov 17, 2017 9:00 am
Hello toaoman!
All i can advice you is to search in google how to open ports.
