Use of "storage" field in default.json file
ghartaan
Post by ghartaan » Tue Sep 26, 2017 6:36 am
What is the use of "storage" field in /etc/onlyofffice/documentserver/default.json ?
"storage": {
"name": "storage-fs",
"fs": {
"folderPath": "",
"urlExpires": 2592000,
"secretString": "onlyoffice"
"region": "",
"endpoint": "http://localhost/s3",
"bucketName": "cache",
"storageFolderName": "files",
"urlExpires": 604800,
"accessKeyId": "AKID",
"secretAccessKey": "SECRET",
"useRequestToGetUrl": false,
"useSignedUrl": false,
"externalHost": ""
Can i use these configuration to store generated files to s3 location instead ?
Re: Use of "storage" field in default.json file
Post by Maxim » Fri Sep 29, 2017 9:42 am
We planed to implement s3 support but for now it's not actual.
bgies
Post by bgies » Thu Feb 22, 2018 8:27 am
Is this still the case? Our files are on an S3 server, and it would be great to have OnlyOffice able to retrieve and save the files to the S3.
Alternatively, what is the next best option for using an S3? What code do I need to change? What events do I have to handle?
