I'm looking for an example of a document editor macro to do a global search and replace.
Do I need a loop using GetElement to fetch each paragraph one at a time for the search and replace or is there a way to select the entire document and search and replace in that manner?
Thanks,
Dan
Global searchandreplace macro for documents
Re: Global searchandreplace macro for documents
Hello Dan,
The SearchAndReplace method is applied to the whole document. Here is an example:
var oDocument = Api.GetDocument();
var oParagraph = oDocument.GetElement(0);
oParagraph.AddText("This is just a sample text. Nothing special.");
oDocument.SearchAndReplace({"searchString": "just", "replaceString": "111111"})
Thank you sir!
With your example Carl, I wrote a macro to replace smart quotes with straight quotes:
(function()
oDocument.SearchAndReplace({"searchString": '“', "replaceString": '"'});
oDocument.SearchAndReplace({"searchString": '”', "replaceString": '"'});
Is there a way of making macros global? I'd like to make this macro available to all OO users for all documents.
Thanks,
Dan
(function()
Thanks,
Dan
Hello Dan,
Unfortunately, macros are attached to specific documents and there is no way to make them global. However, you can write a plugin that will be loaded for all users. Here are our example plugins that work with search&replace functionality:
https://github.com/ONLYOFFICE/sdkjs-plu ... ch_replace
https://github.com/ONLYOFFICE/sdkjs-plu ... aceOnStart
How to install plugins:
https://api.onlyoffice.com/plugin/installation
