The config. Json is not found
luodashuai
Post by luodashuai » Tue Jun 09, 2020 8:59 am
Every time a document is opened, an error is reported that the config.json file under the project path cannot be found, but this error does not affect document editing and other functions.Can someone explain what the config.json file under the project path is used for?
MikhailS
Re: The config. Json is not found
Post by MikhailS » Fri Jul 24, 2020 12:41 pm
Please describe what you mentioned in more details.
Also, please provide some additional information about:
1. Specify what the product you are using? Are you using Community Server + Document Server or just Document Server + your DMS or something else?
2. OS of the server where ONLYOFFICE is installed.
3. Type of installation (exe, docker, deb/rpm).
4. Version of ONLYOFFICE components installed (Community Server, Document Server, Control Panel).
5. How you performed installation, send me also the link to the guide you used.
6. Reproduce the issue with browser console open and make screenshots of error messages in Network and Console tabs.
7. Please send me a screenshot or .gif of the error you get in web interface.
