DocumentServer SpellChecker does not work
kaiserben
Post by kaiserben » Thu Oct 03, 2019 3:40 pm
I have installed ONLYOFFICE, everything works fine only the SpellChecker.
Can someone help me ?
Regards,
Andrew
Re: DocumentServer SpellChecker does not work
Post by Andrew » Tue Oct 15, 2019 11:45 am
Hello kaiserben,
Please specify additional information about your installation:
1. OS of the server where ONLYOFFICE Document Server is installed.
2. Type of installation of Document Server (docker, deb/rpm).
3. Which guide link did you use for installation.
4. Version of Document Server installed.
5. What document storage system do you use for integration with Document Server?
kaiserben
Post by kaiserben » Wed Oct 16, 2019 3:02 pm
Good morning Andrew,
1. OS of the server where ONLYOFFICE Document Server is installed : ONLYOFFICE Document Server is installed on my local computer under windows 10
2. Type of installation of Document Server (docker, deb/rpm). : see below
3. Which guide link did you use for installation. : https://helpcenter.onlyoffice.com/serve ... -apps.aspx
4. Version of Document Server installed. : v5.4
5. What document storage system do you use for integration with Document Server? FileManager : https://github.com/servocoder/RichFilemanager
Thank you for your feedback
