Requesting Help in API connection via PHP
adamg
Post by adamg » Mon Feb 04, 2019 10:47 pm
Hi All,
I am wondering if there is anyone out there that can assist me with some template code on how to generate and authenticate to the CRM portal (Nothing document related)
I have been unsuccessful in my attempts to generate a code and create the authentication request as per https://api.onlyoffice.com/portals/meth ... entication
My Non working code
<?php
$url = 'http://MYORG.onlyoffice.com/api/2.0/authentication';
// A very simple PHP example that sends a HTTP POST to a remote site
$data = array("userName" => "MY_EMAIL", "password" => "MY PASSWORD");
$data_string = json_encode($data);
$ch = curl_init($url);
curl_setopt($ch, CURLOPT_POST, 1);
curl_setopt($ch, CURLOPT_POSTFIELDS,$data_string);
curl_setopt($ch, CURLOPT_RETURNTRANSFER, true);
curl_setopt($ch, CURLOPT_HTTPHEADER, array(
    'Content-Type: application/json',
    'Content-Length: ' . strlen($data_string))
// In real life you should use something like:
// curl_setopt($ch, CURLOPT_POSTFIELDS,
//          http_build_query(array('postvar1' => 'value1')));
// Receive server response ...
$server_output = curl_exec($ch);
curl_close ($ch);
print_r($server_output);  //Try and get some form of output
// Further processing ...
if ($server_output == "OK") { echo "WIN"; } else { echo "FAIL"; }
I'm obviously missing fundermental understanding and would really appreciate anyones help
Re: Requesting Help in API connection via PHP
Post by Carl » Tue Feb 05, 2019 7:50 am
The issue is in
The authentication request returns a response like described here: https://api.onlyoffice.com/portals/auth
This response is not "OK", so you get a "FAIL" result.
adamg
Post by adamg » Wed Feb 06, 2019 1:12 am
Hi Carl,
Thanks for your prompt input. Very much appreciated.
I currently cant get anything from $server_output.
Can you see anything above that would indicate it not work?
As im not great at getting these authentications started the https://api.onlyoffice.com/portals/auth page doesnt give me what im missing.
I assumed i was already performing a CURLrequest as per the example.
I have tried a few variations of this with the headers too.
In short, my insufficient knowledge at this stage has prevented me moving forward.
Any advice would be appreciated.
