Menu Bar on macOS
svoop
Menu Bar on macOS
Post by svoop » Sun Jun 07, 2020 2:52 pm
Hi
Is there a way to hide the dark blue "document bar" (marked red in the below screenshot)? The functions (save, print, undo, redo) are already available in the macOS menu bar and the file name is displayed in the document tab above.
Thanks for your hints!
Screen Shot 2020-06-07 at 16.48.41.png (150.22 KiB) Viewed 409 times
MikhailS
Re: Menu Bar on macOS
Post by MikhailS » Fri Jul 24, 2020 12:37 pm
Unfortunately, there is no such possibility.
These buttons and the file name cannot be removed.
