How to force set CoAuthoring autoAssembly to true by default?
Murz
Post by Murz » Mon Feb 17, 2020 6:02 am
I configure Onlyoffice server in Docker container with Seafile integration via manual: https://download.seafile.com/published/ ... _office.md and have problems with auto saving documents using default settings. Proposed solution is enable autosave (autoAssembly) at interval via editing /etc/onlyoffice/documentserver/local.json:
    "services": {
        "CoAuthoring": {
            "autoAssembly": {
                "enable": true,
                "interval": "5m"
This works well, but the problem that after each restart "local.json" file is overwritten. How can I force set CoAuthoring autoAssembly values in Onlyoffice server, for work without modifying file manually at each restart?
Re: How to force set CoAuthoring autoAssembly to true by default?
Post by Carl » Mon Feb 17, 2020 2:14 pm
You can create a new config file with this parameter inside the container /etc/onlyoffice/documentserver/local-production-linux.json and mount it on host:
-v ./local-production-linux.json:/etc/onlyoffice/documentserver/local-production-linux.json
This way you will not lose the parameter value on container restart.
alexw
Post by alexw » Thu Jun 18, 2020 5:46 pm
This solution does not work anymore in the current documentserver docker container.
When starting the container the following error message appears:
ds:docservice: ERROR (not running)
ds:docservice: ERROR (spawn error)
ds:converter: ERROR (not running)
ds:converter: ERROR (spawn error)
it does not matter if the file is created inside the container or is mounted.
Post by Carl » Thu Jun 25, 2020 3:49 pm
Hello alexw,
Please provide the content of your local-production-linux.json file so we can check if there are any issues with its structure. Also specify the version of the Document Server you are using.
alexw
Post by alexw » Fri Jun 26, 2020 11:17 pm
my mistake - the code pasted from post 1 of this thread has a minor mistake - it has one too many { symbols at the beginning:
    "services": {
        "CoAuthoring": {
            "autoAssembly": {
                "enable": true,
                "interval": "5m"
the correct text to paste (as it is correctly shown in the seafile document) should be:
    "services": {
        "CoAuthoring": {
            "autoAssembly": {
                "enable": true,
                "interval": "5m"
