Setting up a third party email client
scott
Post by scott » Fri Sep 13, 2019 7:00 am
Hello ONLYOFFICE Developers
Email is working great with the mail server and the ONLYOFFICE portal. I would like to get a third party email client to work with the ONLYOFFICE mail server. I found how to set a password for access to my mail account but I'm not sure what the password for it's internal SMTP server is or it's user name. Using the same credentials as my mail account doesn't seem to work. Is there a guide somewhere for third party email integration?
Thank you!
MikhailS
Re: Setting up a third party email client
Post by MikhailS » Mon Sep 16, 2019 2:21 pm
Hello.
To connect third party email client to your portal you should click on Connection Settings in context menu of your account in Mail module and enter data of your third party email client.
Also, make sure that you are using Community Server v.10, because this functional is working only on this version.
