Errors in docservice and spellchecker out.log
timurt
Post by timurt » Tue Apr 09, 2019 9:30 am
I'v installed document server v5.2 on Debian 9.7. It seems as all working, but there are hundreds of errors in the docservice and spellchecker out.log files such as
docservice
[2019-04-09T11:04:08.203] [WARN] nodeJS - worker 2332 died (code = 1; signal = null).
[2019-04-09T11:04:08.209] [WARN] nodeJS - worker 2363 started.
[2019-04-09T11:04:08.649] [WARN] nodeJS - Express server starting...
[2019-04-09T11:04:09.444] [ERROR] nodeJS - Tue, 09 Apr 2019 09:04:09 GMT uncaughtException: bind EADDRINUSE null:8000
[2019-04-09T11:04:09.445] [ERROR] nodeJS - Error: bind EADDRINUSE null:8000
at listenOnMasterHandle (net.js:1420:16)
at rr (internal/cluster/child.js:121:12)
at Worker.send (internal/cluster/child.js:88:7)
at process.onInternalMessage (internal/cluster/utils.js:42:8)
at emitTwo (events.js:131:20)
at process.emit (events.js:214:7)
at emit (internal/child_process.js:762:12)
at _combinedTickCallback (internal/process/next_tick.js:142:11)
at process._tickCallback (internal/process/next_tick.js:181:9)
spellchecker
[2019-04-09T11:06:20.424] [WARN] nodeJS - worker 5367 died (code = 1; signal = null). restart...
[2019-04-09T11:06:21.056] [WARN] nodeJS - Express server starting...
[2019-04-09T11:06:21.118] [ERROR] nodeJS - Tue, 09 Apr 2019 09:06:21 GMT uncaughtException: bind EADDRINUSE null:8080
[2019-04-09T11:06:21.119] [ERROR] nodeJS - Error: bind EADDRINUSE null:8080
All services listen to the appropriate ports
netstat -tanp | grep 8000
tcp6 0 0 :::8000 :::* LISTEN 20055/node
netstat -tanp | grep 8080
tcp6 0 0 :::8080 :::* LISTEN 20053/node
ps -ef|grep 20055
onlyoff+ 20055 1 0 Apr05 ? 00:00:59 node --max_old_space_size=4096 /var/www/onlyoffice/documentserver/server/DocService/sources/server.js
onlyoff+ 20130 20055 0 Apr05 ? 00:02:02 /usr/bin/node --max_old_space_size=4096 /var/www/onlyoffice/documentserver/server/DocService/sources/server.js
ps -ef|grep 20053
onlyoff+ 20053 1 0 Apr05 ? 00:00:23 node /var/www/onlyoffice/documentserver/server/SpellChecker/sources/server.js
onlyoff+ 20111 20053 0 Apr05 ? 00:00:39 /usr/bin/node /var/www/onlyoffice/documentserver/server/SpellChecker/sources/server.js
What is the problem, how to solve it?
Сan you help please.
Thanks
Re: Errors in docservice and spellchecker out.log
Post by Maxim » Sun Aug 04, 2019 7:18 pm
Hello timurt!
Document server works?
