Is it possible as a user to set the preferred format for dispalyed dates?
enzocontini
Post by enzocontini » Thu Jan 10, 2019 12:52 pm
In a project I follow that is using OnlyOffice as a document repository I always see all dates in a format I am used to.
Is it possible for me (as a user) to set some preference somewhere in order to se dates in the DD/MM/YYYY format?
Re: Is it possible as a user to set the preferred format for dispalyed dates?
Post by Maxim » Fri Jan 11, 2019 11:54 am
Hello enzocontini!
Displaying DD/MM/YYYY format depends on chosen language in your profile.
If you set 'Great Britain' it will be DD/MM/YYYY, but if you set 'United States' it will be MM/DD/YYYY.
enzocontini
Post by enzocontini » Fri Jan 11, 2019 2:42 pm
Thank you so much Maxim!! ;-)
