Could not detect any host
maxxer
Post by maxxer » Wed Apr 21, 2021 7:47 am
Hi
I’ve installed OO as system packages on Ubuntu 20. I configured local.json this way:
  "services": {
    "CoAuthoring": {
      "token": {
        "enable": {
          "request": {
            "inbox": true,
            "outbox": true
          "browser": true
        "inbox": {
          "inBody": false
        "outbox": {
          "inBody": false
      "secret": {
        "inbox": {
          "string": "abc"
        "outbox": {
          "string": "abc"
        "session": {
          "string": "abc"
Unfortunately I still get Could not detect any host when checking config. I did search around but couldn’t find where the error comes from… I found this working config with Docker, I think I copied all the configs but still getting that error.
thanks
Re: Could not detect any host
Post by Carl » Wed Apr 21, 2021 1:47 pm
Please specify the guide you used to install the Document Server and attach a screenshot of the error message you see.
maxxer
Post by maxxer » Wed Apr 21, 2021 7:22 pm
I used this guide.
Here's the screen of the error with the ajax call
thanks
maxxer
Post by maxxer » Wed Apr 28, 2021 2:01 pm
What other options do I have? Install with Docker?
Post by Carl » Mon May 03, 2021 7:34 am
Please reproduce the issue and provide the following:
1. Error entry from Nextcloud log related to the issue.
2. Document Server log file converter/out.log
3. Check the availability of NC and DS to each other with wget command
wget https://DS_address from the machine with NC
wget https://NC_address from the machine with DS
