Error when trying to add onlyoffice to nextcloud.
phillw
Post by phillw » Mon Dec 09, 2019 12:44 pm
Hi folks,
onlyoffice is installed with working let's encrypt certificate, as is nextcloud. (on separate servers). When trying to connect from the nextcloud server I get the error
Error when trying to connect (Error occurred in the document service: Error while downloading the document file to be converted.)
The only office can successfully
wget https://nc.phillw.org
and the next cloud one
wget://https://oo.phillw.org
Any ideas of where to look?
Thanks in advance,
Phill.
Re: Error when trying to add onlyoffice to nextcloud.
Post by Carl » Mon Dec 09, 2019 12:52 pm
Hello Phill,
Errors of such type can be found in /var/log/onlyoffice/documentserver/converter/out.log of the Document Server. Please check it and let me know the error.
phillw
Post by phillw » Mon Dec 09, 2019 1:11 pm
Wow,
thanks for the speedy reply!! As requested...
[2019-12-09T13:01:10.858] [ERROR] nodeJS - error downloadFile:url=https://nc.phillw.org/index.php/apps/on ... 1585_docx)
Regards,
Phill.
Post by Carl » Wed Dec 11, 2019 7:02 am
Hello Phill,
This is not a full error log. Please copy the whole excerpt with the error between two time stamps.
phillw
Post by phillw » Wed Dec 11, 2019 9:13 am
here is the full log..
[2019-12-09T12:24:00.192] [ERROR] nodeJS - error downloadFile:url=https://nc.phillw.org/index.php/apps/on ... bGciOiJIUz$
TypeError: First argument should be a valid curve name
at TypeError (native)
at Object.createSecureContext (_tls_common.js:95:15)
at Object.exports.connect (_tls_wrap.js:1032:48)
at Agent.createConnection (https.js:84:22)
at Agent.createSocket (_http_agent.js:185:26)
at Agent.addRequest (_http_agent.js:152:10)
at new ClientRequest (_http_client.js:174:16)
at Object.exports.request (http.js:33:10)
at Object.exports.request (https.js:208:15)
at Request.start (/var/www/onlyoffice/documentserver/server/Common/node_modules/request/request.js:751:32)
at Request.end (/var/www/onlyoffice/documentserver/server/Common/node_modules/request/request.js:1511:10)
at end (/var/www/onlyoffice/documentserver/server/Common/node_modules/request/request.js:564:14)
at Immediate.<anonymous> (/var/www/onlyoffice/documentserver/server/Common/node_modules/request/request.js:578:7)
at runCallback (timers.js:672:20)
at tryOnImmediate (timers.js:645:5)
at processImmediate [as _immediateCallback] (timers.js:617:5)
Regards,
Phill.
Post by Carl » Wed Dec 11, 2019 10:03 am
Hello Phill,
Thank you for the info. Please specify the version of the Document Server installed, OS of the server where it is installed and its type of installation (docker, deb/rpm).
phillw
Post by phillw » Wed Dec 11, 2019 7:53 pm
Hi, Server is CentOS 7, brand new insrall and fully updated. SELinux is in enforcing mode.
The installation was carried out using your instructions at https://helpcenter.onlyoffice.com/de/se ... entos.aspx
https://oo.phillw.org/welcome/ reports the server is running
Regards,
Phill.
{edit} Oh, I forgot to mention, the next cloud instance connects fine to your public server instnce.
Post by Carl » Thu Dec 12, 2019 1:25 pm
Hello Phill,
Thank you for the info once again. Please specify the version of NodeJS installed on your server. Use the command
node --version
Also please try to disable certificate verification in /etc/onlyoffice/documentserver/default.json => set rejectUnauthorized to false => save the file and restart all Document Server services with
supervisorctl restart all
phillw
Post by phillw » Thu Dec 12, 2019 9:07 pm
[root@oo ~]# node --version
v6.17.1
did as suggested and here is the error...
[2019-12-12T21:04:25.978] [ERROR] nodeJS - error downloadFile:url=https://nc.phillw.org/index.php/apps/on ... 0658_docx)
Regards,
Phill.
phillw
Post by phillw » Mon Dec 16, 2019 5:02 am
as this is brand new installation, if you would like log-in credentials to investigate further I'd be more than happy to set that up for you good people.
Regards,
Phill.
