no live upstreams while connecting to upstream
PascalB
Post by PascalB » Mon Oct 21, 2019 1:26 pm
Nextcloud (latest version) is unable to connect to Onlyffice (latest version).
it seems there are some problems with upstream.
nginx.error.log, i have :
[error] 1957#1957: *4 no live upstreams while connecting to upstream
[error] 1957#1957: *1 connect() failed (111: Connection refused)
i don't know where to check and how to solve it, thanks for your help :) .
Pascal
Andrew
Re: no live upstreams while connecting to upstream
Post by Andrew » Tue Oct 22, 2019 9:49 am
Hello PascalB,
Do you install Nextcloud and Document Server on same machine?
Please specify OS and installation type for Document Server (Windows, docker, deb/rpm).
Please specify guide link which you used for installation and all steps you took to install Nextcloud and Document Server.
Do you use proxy/firewall in your configuration?
