Nextcloud and OnlyOffice under one domain and different paths
User avatar
dasarne
Post by dasarne » Fri Oct 11, 2019 9:51 pm
Hello everybody,
I only have one domain so all services there have to live under different paths. On the server is a Nextcloud server, which is reachable under https://my.domain.de/nc and a OnlyOffice server, which is reachable under https://my.domain.de/oo.
The OnlyOffice server is in a Docker container (where I haven't changed anything), which can be reached under localhost:8880. With the instructions found at https://helpcenter.onlyoffice.com/serve ... proxy.aspx I created the following Proyx-Configuration:
 #OnlyOffice Proxy
       Define VPATH /oo
       Define DS_ADDRESS localhost:8880
       <Location ${VPATH}>
               Require all granted
               SetEnvIf Host "^(.*)$" THE_HOST=$1
               RequestHeader setifempty X-Forwarded-Proto https
               RequestHeader setifempty X-Forwarded-Host %{THE_HOST}e
               RequestHeader edit X-Forwarded-Host (.*) $1${VPATH}
               ProxyAddHeaders Off
       </Location>
       ProxyPassMatch ^\${VPATH}(.*)(\/websocket)$ "ws://${DS_ADDRESS}/$1$2"
       ProxyPass ${VPATH} "http://${DS_ADDRESS}"
       ProxyPassReverse ${VPATH} "http://${DS_ADDRESS}"
Btw.: This configuration must be made for http and https, otherwise you got into trouble because the Nextcloud ONLYOFFICE integration app tries to access `GET http:\/\/my.domain.de\/oo\/cache\/files\/conv_check_876410214_docx\/output.docx\/check_876410214.docx?md5=VFrBl1Q7QHirw4DQXqMPQg&expires=1570827540&disposition=attachment&ooname=output.docx` which fails when there is no http configured. :roll:
I can now configure the OnlyOffice Url in the Nextcloud ONLYOFFICE integration app and get a connection. :D
If I now try to edit a document e.g. Test.docx I got the message
ONLYOFFICE is currently not available appears. Please contact your administrator
The log output of the OnlyOffice Docker container does not output a message.
  • How do I get more information?
  • What am I doing wrong?
  • Is it even possible to operate OnlyOffice and NextCloud under one domain with different paths?
Yours
Arne
Never a failure, but always a lesson.
Re: Nextcloud and OnlyOffice under one domain and different paths
Post by Carl » Thu Nov 07, 2019 7:35 am
Hello Arne,
Sorry for the delayed reply.
Please open the browser console and make screenshots of errors in Console and Network tab when trying to open a document.
