Error when trying to connect (cURL error 35: error:1408F10B:SSL routines:ssl3
toolmanz
Post by toolmanz » Wed Jun 05, 2019 4:31 pm
I am running an Unraid <latest ver> server and I have Nextcloud <latest ver> running with no problems.
It syncs and I can access nextcloud externally through a reverse proxy <using duckdns>.
Installed onlyoffice docker container <latest ver> and when I use the webui it tells me it is running.
But, when I configure the integrator in nextcloud apps I get the following error code:
Error when trying to connect (cURL error 35: error:1408F10B:SSL routines:ssl3_get_record:wrong version number (see http://curl.haxx.se/libcurl/c/libcurl-errors.html)) :roll:
I created my own SSL certs and placed them in the folder appdata/onlyofficeds/Data/certs.
The onlyoffice options do not show up after I restart the nextcloud and onlyoffice dockers.
It's probably something dumb on my behalf but I'm just not seeing it. :oops:
Any help would be appreciated and thanks in advance.
Toolmanz
Re: Error when trying to connect (cURL error 35: error:1408F10B:SSL routines:ssl3
Post by Maxim » Thu Jun 13, 2019 10:41 am
Try to add to Nextcloud config /var/www/nextcloud/config/config.php
'onlyoffice' =>
  array (
    'verify_peer_off' => false,
    'jwt_header' => "AuthorizationJwt"
