Problem to integrate onlyoffice to nextcloud
tomxemerica99x
Post by tomxemerica99x » Tue May 28, 2019 6:40 am
Hello! I am new here and would need your help.
I have a server with nextcloud 16.0.1 and I want to integrate onlyoffice there. i have the docker installed and it works too. I changed the password in the config. when integrated in nextcloud comes the following error (pic). Thank you for your help
https://tombine.eu/index.php/s/G5xbHjCP8mCG4bm
https://tombine.eu/index.php/s/BpwmXjTao4DSAjW
Re: Problem to integrate onlyoffice to nextcloud
Post by Maxim » Tue May 28, 2019 7:56 am
Nextcloud and Document Server were instelled on the same server?
tomxemerica99x
Post by tomxemerica99x » Tue May 28, 2019 9:34 am
hy! yes, nextcloud and docker on the same server.
Post by Maxim » Tue May 28, 2019 11:50 am
I recommend you to follow our instruction
tomxemerica99x
Post by tomxemerica99x » Fri May 31, 2019 2:30 pm
hy!
I have now uninstalled the docker because I did not get it running. can anyone give me a step by step installation guide for debian (install the docker - install the nextcloud integration app )
thanks
Post by Maxim » Mon Jun 03, 2019 8:31 am
Follow this instruction to install using Docker
