Nextcloud (non Docker) w/ ONLYOFFICE Document Server (Dockerized) (Error occured in the document service)
jason2019
Post by jason2019 » Sat Mar 23, 2019 2:00 pm
Reference
1. Nextcloud Installation
https://websiteforstudents.com/install- ... t-ssl-tls/
I use Nextcloud (I am planning to integrate with Zimbra too)
No issues.
2. ONLYOFFICE Document Server Installation
https://help.nextcloud.com/t/howto-what ... host/33192
Edit: I will censor my domain as I am not an IT expert, less security. Thank you.
cat /etc/hosts
127.0.0.1       localhost       cloud.x.com      docs.x.com
# The following lines are desirable for IPv6 capable hosts
::1     localhost ip6-localhost ip6-loopback
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
cat /etc/apache2/sites-available/onlyoffice-le*
<IfModule mod_ssl.c>
<VirtualHost *:443>
     ServerName docs.x.com
RewriteEngine on
# Some rewrite rules in this file were disabled on your HTTPS site,
# because they have the potential to create redirection loops.
# RewriteCond %{SERVER_NAME} =docs.x.com
# RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI} [END,NE,R=permanent]
SSLCertificateFile /etc/letsencrypt/live/docs.x.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/docs.x.com/privkey.pem
Include /etc/letsencrypt/options-ssl-apache.conf
SetEnvIf Host "^(.*)$" THE_HOST=$1
RequestHeader setifempty X-Forwarded-Proto http
RequestHeader setifempty X-Forwarded-Host %{THE_HOST}e
ProxyAddHeaders Off
ProxyPassMatch (.*)(/websocket)$ "ws://127.0.0.1:81/$1$2"
ProxyPass / "http://127.0.0.1:81/"
ProxyPassReverse / "http://127.0.0.1:81"
</VirtualHost>
</IfModule>
End of result
1. Nextcloud is running
2. ONLYOFFICE Document Server is running
3. However, Nextcloud were unable to connect to ONLYOFFICE. Document Editing Service address: https://docs.x.com Error when trying to connect (Error occured in the document service)
Re: Nextcloud (non Docker) w/ ONLYOFFICE Document Server (Dockerized) (Error occured in the document service)
Post by Carl » Wed Mar 27, 2019 7:56 am
Please check Document Server logs for errors:
/app/onlyoffice/DocumentServer/logs/documentserver
