Nextcloud ONLYOFFICE integration not working
abdulocracy
Post by abdulocracy » Mon Feb 04, 2019 2:42 pm
I have been trying to integrate ONLYOFFICE with my Nextcloud instance by installing it on the same machine via Docker and connecting them with the integration app for Nextcloud. I have Document Server running on port 44301, which works when I try to access from the browser, with configured SSL.
My problem is, when I enter the Document Server address into the integration app, I get an error. I have tried 0.0.0.0:44301, 127.0.0/1.1:44301, <mydomain>:44301, but none of them seem to work. I get this error in the Nextcloud logs: "HealthcheckRequest on check error: Bad Request or timeout error"
I would really appreciate it if someone has any idea how to fix this issue. Thanks!
Re: Nextcloud ONLYOFFICE integration not working
Post by Maxim » Tue Feb 05, 2019 6:25 am
Hello abdulocracy!
docker exec -it onlyoffice-document-server bash
wget http(s)://nextcloud_domain
what a result you will get if you run command wget from the docker container to the Nextcloud?
Did you enable HTTPS on Nextcloud?
or you can install Nextcloud and Document Server using docker - instruction
