SSL
wc3717
SSL
Post by wc3717 » Wed Nov 27, 2019 2:27 am
I have installed SSL on my site but Chrome says that it’s not trusted. Also how can I disable SSL on my site if this error is being caused?
Thanks
Andrew
Re: SSL
Post by Andrew » Wed Nov 27, 2019 7:02 am
Hello wc3717,
Please specify:
1. Which of our products do you use.
2. OS, versions of components and type of installation (docker, deb/rpm)
3. Do you use self-signed or CA-signed certificate? Please specify guide which you used to create and install it.
wc3717
Re: SSL
Post by wc3717 » Thu Nov 28, 2019 9:14 am
Thanks
1. I use Community and Document Server (DigitalOcean one click)
2. Ubuntu 18.04 using Docker
3. https://helpcenter.onlyoffice.com/serve ... https.aspx
