high CPU load because of beam.smp
j.koopmann
Post by j.koopmann » Wed Nov 20, 2019 1:17 pm
in my brand new community-edition docker I am noticing 80%+ CPU load from beam.smp within the container even though it is idling. Any ideas?
Regards,
JP
Andrew
Re: high CPU load because of beam.smp
Post by Andrew » Tue Nov 26, 2019 1:51 pm
Hello JP,
We fixed a bug connected to RabbitMQ recently, this commit will be tested and added to future releases, sorry for temporary inconvenience concerning this problem. You can check it here https://github.com/ONLYOFFICE/Docker-Do ... r/pull/193
j.koopmann
Post by j.koopmann » Tue Nov 26, 2019 1:58 pm
Great. I opened a support ticket and posted the solution which is to put
RABBITMQ_SERVER_ADDITIONAL_ERL_ARGS="+S 1:1“
into /etc/rabbitmq/rabbitmq-env.conf. Looks as if the developers took that advice and put it into the new docker config. Thanks.
