Problem with GUI Language Nextcloud/Onlyoffice Docker Documentserver
Medar
Post by Medar » Wed Mar 20, 2019 8:41 am
i got a big Problem with the GUI Language in Documents.
We had a fresh installation with Nexcloud and the Onlyoffice Docker Documentserver.
I just read that the Language should be adopt from the Nextcloud Language but it wont.
Weve got German Language and in Onlyoffice the Language is always English.
I looked in all files (js, html) and changed some rules from lang=en in lang=de but it wont work.
Had anyone an idea how i can force the language in Onlyoffice fix in german?
Thanks so much dudes,
need help fast.
Re: Problem with GUI Language Nextcloud/Onlyoffice Docker Documentserver
Post by Carl » Thu Mar 21, 2019 7:25 am
Hello.
We don't recommend to do that. By default, the language of Document Editor interface must be the same as in Nextcloud. Please specify the versions of Nextcloud, Document Server and ONLYOFFICE connector app.
Medar
Post by Medar » Thu Mar 21, 2019 9:01 am
Iam using the Onlyoffice DOCUMENT SERVER Version: 5.2.8 CE
Version of Nextcloud: 15.05 and ONLYOFFICE connector app: 2.1.2
i undo all chances within an fresh installation but they dont adopt the language!
They are installes on the same Server with an Docker and a Proxy and listening on Port: 8443
Medar
Post by Medar » Fri Mar 22, 2019 8:36 am
Okay Problem got more offensive!
All Browsers will Display the language in German.
But Google Chrome only Display the language in English.
Just installed a fresh Windows with chrome without any cache or somethink else and the language is English.
Firefox, Internet Exlplorer, Safari and and and will display in german.
i dont know anymore what to do xD.
Please help
Thorsten Seifried
Post by Thorsten Seifried » Thu Sep 05, 2019 2:01 pm
Hello Medar,
do you have a solution for this problem.
We have exactly the same problem.
Thank you very much in advance.
Best regards,
Thorsten Seifried
