Need to upgrade OnlyOffice for Nextcloud 14
NoMax
Post by NoMax » Mon Dec 31, 2018 3:04 pm
I just ran the script install to update Nextcloud from V 13 to V 14. However, after updating OnlyOffice no longer functions, and my only option is to Uninstall. I see the following error message in my Nextcloud apps: "This app cannot be installed because the following dependencies are not fulfilled:
Server version 13 or lower is required."
I have OnlyOffice installed in a Docker container. Nextcloud and OnlyOffice are running on the same server. Unfortunately I don't know how to complete the upgrade to get OnlyOffice working again. There is no option to upgrade from within Nextcloud Apps, only Delete is available.
Where can I find complete instructions on how to complete this update?
Thank you.
Re: Need to upgrade OnlyOffice for Nextcloud 14
Post by Carl » Wed Jan 09, 2019 9:47 am
Please specify the version of Document Server you are currently using. In order to update the Document Server container, you need to simply stop the existing container and then run a new one:
Also make sure you have the required connector version installed (https://apps.nextcloud.com/apps/onlyoffice). For Nextcloud v14 you need to have connector app 2.1.2.
Usually the connector app can be upgraded within Nextcloud interface. Please make a screenshot of the app list in Nextcloud where ONLYOFFICE app can be seen.
NoMax
Post by NoMax » Mon Jan 14, 2019 7:26 pm
It looks like I'm running version 1.2.0.
I have attached the screenshot. Please note I have reverted back to Nextcloud 13.
Thanks in advance for any assistance.
NM
Post by Carl » Wed Jan 16, 2019 1:07 pm
In this case I'd recommend to remove the current connector (click Disable => Remove option will appear) and then install the new version in the Nextcloud store.
