Error: Download failed; NC12 and OO
Quale
Post by Quale » Tue Jul 25, 2017 9:33 am
im runnning an Nextcloud 12 Server on Ubuntu Server 16.04 with Apache2 Webserver. And the latest OnlyOffice Docker Container on a seperate Ubuntu Server 16.04.
I installed OnlyOffice with https like in he Help-Center (with my wildcard cetificate):
docker run -i -t -d --restart=always -p 443:443 \
-v /app/onlyoffice/DocumentServer/data:/var/www/onlyoffice/Data onlyoffice/documentserver
The OO Server has the domain https://cloudoffice.company.de and the NC Server https://cloud.company.de
When i open a file the browser displays:
- Warning: The document could not be saved. Please chech connection settings or contact your administrator.......
- Error: Donwload failed. Press "OK" to back up document list.
The Nextcloud server is running fine. I can open both websites from our clients and the certicate is ok.
The OO App in Nextcloud is Version 1.1.3.
I run docker-engine from Docker Repository with version: 17.05.0-ce (noall logs are ok)
Please help me.
Phil
Re: Error: Download failed; NC12 and OO
Post by Maxim » Tue Jul 25, 2017 10:50 am
Hello Phil!
If you make a request to the API of Document Server container just to be sure that Document Server is accessible from NextCoud Server what you get?
wget https://cloudoffice.company.de/web-apps/apps/api/documents/api.js
or just put this link in browser's tab
Quale
Post by Quale » Tue Jul 25, 2017 12:00 pm
Hi, im getting this from the server:
--2017-07-25 13:50:17--  https://cloudoffice.company.de/web-apps/apps/api/documents/api.js
Auflösen des Hostnamen »cloudoffice.company.de (cloudoffice.company.de)«... 10.10.145.22
Verbindungsaufbau zu cloudoffice.company.de (cloudoffice.company.de)|10.10.145.22|:443... verbunden.
FEHLER: Kann das Zertifikat von »cloudoffice.company.de« nicht prüfen, ausgestellt von »»CN=thawte DV SSL CA - G2,OU=Domain Validated SSL,O=thawte\\, Inc.,C=US««:.
  Die Authorität des Ausstellers des Zertifikates kann lokal nicht geprüft werden.
Verwenden Sie »--no-check-certificate«, um zu dem Server »cloudoffice.company.de« eine nicht gesicherte Verbindung aufzubauen.
The servers are in our DMZ and didn't know that they are in the domain *.company.de.
I edited the /etc/hosts file, so they can connect to each other with their company domain names. The nextcloud server name ist hstvcloud01 and the onlyoffice server name is hstvcloud02. But they use the domain name to connect in the settings in nextcloud.
in a browser from a domain client:
 * Copyright (c) Ascensio System SIA 2013. All rights reserved
 * http://www.onlyoffice.com
;(function(DocsAPI, window, document, undefined) {
        # Full #
        config = {
            type: 'desktop or mobile',
            width: '100% by default',
            height: '100% by default',
            documentType: 'text' | 'spreadsheet' | 'presentation',
            document: {
                title: 'document title',
                url: 'document url'
                fileType: 'document file type',
                options: <advanced options>,
                key: 'key',
                vkey: 'vkey',
                info: {
                    author: 'author name',
                    folder: 'path to document',
                    created: '<creation date>',
                    sharingSettings: [
                            user: 'user name',
                            permissions: '<permissions>',
                            isLink: false
                permissions: {
                    edit: <can edit>, // default = true
                    download: <can download>, // default = true
                    reader: <can view in readable mode>,
                    review: <can review>, // default = edit
                    print: <can print>, // default = true
                    rename: <can rename>, // default = false
                    changeHistory: <can change history>, // default = false
                    comment: <can comment in view mode> // default = edit
            editorConfig: {
                mode: 'view or edit',
                lang: <language code>,
                canCoAuthoring: <can coauthoring documents>,
                canBackToFolder: <can return to folder> - deprecated. use "customization.goback" parameter,
                createUrl: 'create document url',
                sharingSettingsUrl: 'document sharing settings url',
                fileChoiceUrl: 'mail merge sources url',
                callbackUrl: <url for connection between sdk and portal>,
                mergeFolderUrl: 'folder for saving merged file',
                licenseUrl: <url for license>,
                customerId: <customer id>,
                user: {
                recent: [
                        url: 'document url',
                templates: [
                        icon: 'template icon url',
                        url: 'http://...'
                customization: {
                    logo: {
                        image: url,
                        imageEmbedded: url,
                        url: http://...
                    backgroundColor: 'header background color',
                    textColor: 'header text color',
                    customer: {
                        address: 'New-York, 125f-25',
                        mail: 'support@gmail.com',
                        www: 'www.superpuper.com',
                        info: 'Some info',
                        logo: ''
                    about: true,
                    feedback: {
                        visible: false,
                        url: http://...
                    goback: {
                        url: 'http://...',
                        text: 'Go to London'
                    chat: true,
                    comments: true,
                    zoom: 100,
                    compactToolbar: false,
                    leftMenu: true,
                    rightMenu: true,
                    toolbar: true,
                    header: true,
                    statusBar: true,
                    autosave: true,
                    forcesave: false,
                    commentAuthorOnly: false,
                    showReviewChanges: false
                plugins: {
                    autoStartGuid: 'asc.{FFE1F462-1EA2-4391-990D-4CC84940B754}',
                    url: '../../../../sdkjs-plugins/',
                    pluginsData: [
                        "helloworld/config.json",
                        "chess/config.json",
                        "speech/config.json",
                        "clipart/config.json",
            events: {
                'onReady': <document ready callback>,
                'onBack': <back to folder callback>,
                'onDocumentStateChange': <document state changed callback>
        # Embedded #
        config = {
            type: 'embedded',
            document: {
                key: 'key',
                vkey: 'vkey'
            editorConfig: {
                autostart: 'document',    // action for app's autostart. for presentations default value is 'player'
                embedded: {
                     embedUrl: 'url',
                     fullscreenUrl: 'url',
                     saveUrl: 'url',
                     shareUrl: 'url',
                     toolbarDocked: 'top or bottom'
            events: {
                'onError': <error callback>,
    // TODO: allow several instances on one page simultaneously
    DocsAPI.DocEditor = function(placeholderId, config) {
        var _self = this,
            _config = config || {};
        extend(_config, DocsAPI.DocEditor.defaultConfig);
        _config.editorConfig.canUseHistory = _config.events && !!_config.events.onRequestHistory;
        _config.editorConfig.canHistoryClose = _config.events && !!_config.events.onRequestHistoryClose;
        _config.editorConfig.canHistoryRestore = _config.events && !!_config.events.onRequestRestore;
        _config.editorConfig.canSendEmailAddresses = _config.events && !!_config.events.onRequestEmailAddresses;
        _config.editorConfig.canRequestEditRights = _config.events && !!_config.events.onRequestEditRights;
        _config.frameEditorId = placeholderId;
        var onMouseUp = function (evt) {
            _processMouse(evt);
        var _attachMouseEvents = function() {
            if (window.addEventListener) {
                window.addEventListener("mouseup", onMouseUp, false)
            } else if (window.attachEvent) {
                window.attachEvent("onmouseup", onMouseUp);
        var _detachMouseEvents = function() {
            if (window.removeEventListener) {
                window.removeEventListener("mouseup", onMouseUp, false)
            } else if (window.detachEvent) {
                window.detachEvent("onmouseup", onMouseUp);
        var _onReady = function() {
            if (_config.type === 'mobile') {
                document.body.onfocus = function(e) {
                    setTimeout(function(){
                        iframe.contentWindow.focus();
                        _sendCommand({
                            command: 'resetFocus',
                            data: {}
                    }, 10);
            _attachMouseEvents();
            if (_config.editorConfig) {
                _init(_config.editorConfig);
            if (_config.document) {
                _openDocument(_config.document);
        var _callLocalStorage = function(data) {
            if (data.cmd == 'get') {
                if (data.keys && data.keys.length) {
                    var af = data.keys.split(','), re = af[0];
                    for (i = 0; ++i < af.length;)
                        re += '|' + af[i];
                    re = new RegExp(re); k = {};
                    for (i in localStorage)
                        if (re.test(i)) k[i] = localStorage[i];
                } else {
                    k = localStorage;
                _sendCommand({
                    command: 'internalCommand',
                    data: {
                        type: 'localstorage',
                        keys: k
            } else
            if (data.cmd == 'set') {
                var k = data.keys, i;
                for (i in k) {
                    localStorage.setItem(i, k[i]);
        var _onMessage = function(msg) {
            if ( msg ) {
                if ( msg.type === "onExternalPluginMessage" ) {
                    _sendCommand(msg);
                } else
                if ( msg.frameEditorId == placeholderId ) {
                    var events = _config.events || {},
                        handler = events[msg.event],
                        res;
                    if (msg.event === 'onRequestEditRights' && !handler) {
                        _applyEditRights(false, 'handler isn\'t defined');
                    } else if (msg.event === 'onInternalMessage' && msg.data && msg.data.type == 'localstorage') {
                        _callLocalStorage(msg.data.data);
                    } else {
                        if (msg.event === 'onReady') {
                            _onReady();
                        if (handler) {
                            res = handler.call(_self, {target: _self, data: msg.data});
        var _checkConfigParams = function() {
                if (!_config.document.url || ((typeof _config.document.fileType !== 'string' || _config.document.fileType=='') &&
                                              (typeof _config.documentType !== 'string' || _config.documentType==''))) {
                    window.alert("One or more required parameter for the config object is not set");
                    return false;
                var appMap = {
                        'text': 'docx',
                        'text-pdf': 'pdf',
                        'spreadsheet': 'xlsx',
                        'presentation': 'pptx'
                    }, app;
                if (typeof _config.documentType === 'string' && _config.documentType != '') {
                    app = appMap[_config.documentType.toLowerCase()];
                    if (!app) {
                        window.alert("The \"documentType\" parameter for the config object is invalid. Please correct it.");
                        return false;
                    } else if (typeof _config.document.fileType !== 'string' || _config.document.fileType == '') {
                        _config.document.fileType = app;
                if (typeof _config.document.fileType === 'string' && _config.document.fileType != '') {
                    var type = /^(?:(xls|xlsx|ods|csv|xlst|xlsy|gsheet)|(pps|ppsx|ppt|pptx|odp|pptt|ppty|gslides)|(doc|docx|doct|odt|gdoc|txt|rtf|pdf|mht|htm|html|epub|djvu|xps))$/
                                    .exec(_config.document.fileType);
                    if (!type) {
                        window.alert("The \"document.fileType\" parameter for the config object is invalid. Please correct it.");
                        return false;
                    } else if (typeof _config.documentType !== 'string' || _config.documentType == ''){
                        if (typeof type[1] === 'string') _config.documentType = 'spreadsheet'; else
                        if (typeof type[2] === 'string') _config.documentType = 'presentation'; else
                        if (typeof type[3] === 'string') _config.documentType = 'text';
                var type = /^(?:(pdf|djvu|xps))$/.exec(_config.document.fileType);
                if (type && typeof type[1] === 'string') {
                    if (!_config.document.permissions)
                        _config.document.permissions = {};
                    _config.document.permissions.edit = _config.document.permissions.review = false;
                    _config.editorConfig.canUseHistory = false;
                if (!_config.document.title || _config.document.title=='')
                    _config.document.title = 'Unnamed.' + _config.document.fileType;
                if (!_config.document.key) {
                    _config.document.key = 'xxxxxxxxxxxxxxxxxxxx'.replace(/[x]/g, function (c) {var r = Math.random() * 16 | 0; return r.toString(16);});
                } else if (typeof _config.document.key !== 'string') {
                    window.alert("The \"document.key\" parameter for the config object must be string. Please correct it.");
                    return false;
                _config.document.token = _config.token;
            return true;
        (function() {
            var result = /[\?\&]placement=(\w+)&?/.exec(window.location.search);
            if (!!result && result.length) {
                if (result[1] == 'desktop') {
                    _config.editorConfig.targetApp = result[1];
                    _config.editorConfig.canBackToFolder = false;
                    if (!_config.editorConfig.customization) _config.editorConfig.customization = {};
                    _config.editorConfig.customization.about = false;
        var target = document.getElementById(placeholderId),
            iframe;
        if (target && _checkConfigParams()) {
            iframe = createIframe(_config);
            target.parentNode && target.parentNode.replaceChild(iframe, target);
            var _msgDispatcher = new MessageDispatcher(_onMessage, this);
         cmd = {
         command: 'commandName',
         data: <command specific data>
        var _destroyEditor = function(cmd) {
            var target = document.createElement("div");
            target.setAttribute('id', placeholderId);
            if (iframe) {
                _msgDispatcher && _msgDispatcher.unbindEvents();
                _detachMouseEvents();
                iframe.parentNode && iframe.parentNode.replaceChild(target, iframe);
        var _sendCommand = function(cmd) {
            if (iframe && iframe.contentWindow)
                postMessage(iframe.contentWindow, cmd);
        var _init = function(editorConfig) {
            _sendCommand({
                command: 'init',
                data: {
                    config: editorConfig
        var _openDocument = function(doc) {
            _sendCommand({
                command: 'openDocument',
                data: {
                    doc: doc
        var _showMessage = function(title, msg) {
            msg = msg || title;
            _sendCommand({
                command: 'showMessage',
                data: {
                    msg: msg
        var _applyEditRights = function(allowed, message) {
            _sendCommand({
                command: 'applyEditRights',
                data: {
                    allowed: allowed,
                    message: message
        var _processSaveResult = function(result, message) {
            _sendCommand({
                command: 'processSaveResult',
                data: {
                    result: result,
                    message: message
        // TODO: remove processRightsChange, use denyEditingRights
        var _processRightsChange = function(enabled, message) {
            _sendCommand({
                command: 'processRightsChange',
                data: {
                    enabled: enabled,
                    message: message
        var _denyEditingRights = function(message) {
            _sendCommand({
                data: {
                    enabled: false,
                    message: message
        var _refreshHistory = function(data, message) {
            _sendCommand({
                command: 'refreshHistory',
                data: {
                    data: data,
                    message: message
        var _setHistoryData = function(data, message) {
            _sendCommand({
                command: 'setHistoryData',
                data: {
                    data: data,
                    message: message
        var _setEmailAddresses = function(data) {
            _sendCommand({
                command: 'setEmailAddresses',
                data: {
                    data: data
        var _processMailMerge = function(enabled, message) {
            _sendCommand({
                command: 'processMailMerge',
                data: {
                    enabled: enabled,
                    message: message
        var _downloadAs = function() {
            _sendCommand({
                command: 'downloadAs'
        var _processMouse = function(evt) {
            var r = iframe.getBoundingClientRect();
            var data = {
                type: evt.type,
                x: evt.x - r.left,
                y: evt.y - r.top,
                event: evt
            _sendCommand({
                command: 'processMouse',
                data: data
        var _serviceCommand = function(command, data) {
            _sendCommand({
                data: {
                    command: command,
                    data: data
        return {
            showMessage         : _showMessage,
            processSaveResult   : _processSaveResult,
            processRightsChange : _processRightsChange,
            denyEditingRights   : _denyEditingRights,
            refreshHistory      : _refreshHistory,
            setHistoryData      : _setHistoryData,
            setEmailAddresses   : _setEmailAddresses,
            processMailMerge    : _processMailMerge,
            downloadAs          : _downloadAs,
            serviceCommand      : _serviceCommand,
            attachMouseEvents   : _attachMouseEvents,
            detachMouseEvents   : _detachMouseEvents,
            destroyEditor       : _destroyEditor
    DocsAPI.DocEditor.defaultConfig = {
        type: 'desktop',
        width: '100%',
        height: '100%',
        editorConfig: {
            lang: 'en',
            canCoAuthoring: true,
            customization: {
                about: true,
                feedback: false
    DocsAPI.DocEditor.version = function() {
        return '4.4.2';
    MessageDispatcher = function(fn, scope) {
        var _fn     = fn,
            _scope  = scope || window,
            eventFn = function(msg) {
                _onMessage(msg);
        var _bindEvents = function() {
                window.addEventListener("message", eventFn, false)
                window.attachEvent("onmessage", eventFn);
        var _unbindEvents = function() {
                window.removeEventListener("message", eventFn, false)
                window.detachEvent("onmessage", eventFn);
            // TODO: check message origin
            if (msg && window.JSON) {
                try {
                    var msg = window.JSON.parse(msg.data);
                    if (_fn) {
                        _fn.call(_scope, msg);
                } catch(e) {}
        _bindEvents.call(this);
        return {
            unbindEvents: _unbindEvents
    function getBasePath() {
        var scripts = document.getElementsByTagName('script'),
            match;
        for (var i = scripts.length - 1; i >= 0; i--) {
            match = scripts[i].src.match(/(.*)api\/documents\/api.js/i);
            if (match) {
                return match[1];
        return "";
    function getExtensionPath() {
        if ("undefined" == typeof(extensionParams) || null == extensionParams["url"])
            return null;
        return extensionParams["url"] + "apps/";
    function getAppPath(config) {
        var extensionPath = getExtensionPath(),
            path = extensionPath ? extensionPath : getBasePath(),
            appMap = {
                'text': 'documenteditor',
                'text-pdf': 'documenteditor',
                'spreadsheet': 'spreadsheeteditor',
                'presentation': 'presentationeditor'
            app = appMap['text'];
        if (typeof config.documentType === 'string') {
            app = appMap[config.documentType.toLowerCase()];
        } else
        if (!!config.document && typeof config.document.fileType === 'string') {
            var type = /^(?:(xls|xlsx|ods|csv|xlst|xlsy|gsheet)|(pps|ppsx|ppt|pptx|odp|pptt|ppty|gslides))$/
                            .exec(config.document.fileType);
            if (type) {
                if (typeof type[1] === 'string') app = appMap['spreadsheet']; else
                if (typeof type[2] === 'string') app = appMap['presentation'];
        path += app + "/";
        path += config.type === "mobile"
            ? "mobile"
            : config.type === "embedded"
                ? "embed"
                : "main";
        path += "/index.html";
        return path;
    function getAppParameters(config) {
        var params = "?_dc=2017-07-21-15-20";
        if (config.editorConfig && config.editorConfig.lang)
            params += "&lang=" + config.editorConfig.lang;
        if (config.editorConfig && config.editorConfig.targetApp!=='desktop') {
            if ( (typeof(config.editorConfig.customization) == 'object') && config.editorConfig.customization.loaderName) {
                if (config.editorConfig.customization.loaderName !== 'none') params += "&customer=" + config.editorConfig.customization.loaderName;
            } else
                params += "&customer=ONLYOFFICE";
            if ( (typeof(config.editorConfig.customization) == 'object') && config.editorConfig.customization.loaderLogo) {
                if (config.editorConfig.customization.loaderLogo !== '') params += "&logo=" + config.editorConfig.customization.loaderLogo;
        if (config.frameEditorId)
            params += "&frameEditorId=" + config.frameEditorId;
        return params;
    function createIframe(config) {
        var iframe = document.createElement("iframe");
        iframe.src = getAppPath(config) + getAppParameters(config);
        iframe.width = config.width;
        iframe.height = config.height;
        iframe.align = "top";
        iframe.frameBorder = 0;
        iframe.name = "frameEditor";
        iframe.allowFullscreen = true;
        iframe.setAttribute("allowfullscreen",""); // for IE11
        iframe.setAttribute("onmousewheel",""); // for Safari on Mac
        return iframe;
    function postMessage(wnd, msg) {
        if (wnd && wnd.postMessage && window.JSON) {
            // TODO: specify explicit origin
            wnd.postMessage(window.JSON.stringify(msg), "*");
    function extend(dest, src) {
        for (var prop in src) {
            if (src.hasOwnProperty(prop)) {
                if (typeof dest[prop] === 'undefined') {
                    dest[prop] = src[prop];
                } else
                if (typeof dest[prop] === 'object' &&
                        typeof src[prop] === 'object') {
                    extend(dest[prop], src[prop])
        return dest;
})(window.DocsAPI = window.DocsAPI || {}, window, document);
Post by Maxim » Wed Jul 26, 2017 6:38 am
Hello Quale!
And do your servers work now? Or it still shows the same error?
Quale
Post by Quale » Wed Jul 26, 2017 7:36 am
No. I changed nothing. The hosts files were edited before is tsrted this thread.
I think the problem is that the servers didnt trust their server partner certificates.
I will look into it.
Quale
Post by Quale » Tue Aug 15, 2017 9:03 am
I finally find my solution for the certificate problem. On the nextcloud server i added in the apache2 nextcloud config the intermediate certificate file and on the onlyoffice server i merged the private and intermediate certificate file into one for the onlyoffice.crt.
Not i can wget the file without problems.
But i get these messsage when i open or create a file:
This is the only thing in the logs:
