Hi All,
I'm trying to activate the Mendeley plugin option.
I follow the steps as outlined as directed here: https://www.onlyoffice.com/app-directory/mendeley
When I try to log in, I end up getting a 'waiting' screen (see attached screenshot)
Has anyone here come across this issue?
Has anyone that has come across this issue figured out how to get around it?
Cheers,
-M
Mendeley Installation and Activation Issue
- Attachments
- Screenshot from 2020-12-16 00-30-51.png (35.04 KiB) Viewed 290 times
Re: Mendeley Installation and Activation Issue
Hello mhollander,
Unfortunately, our Desktop Editors do not support Mendeley plugin. You can use it only when working via browser.
Hello mhollander,
A little update: Desktop Editors don't support Mendeley plugin, when working on a file locally.
The fact that it doesn't work when you connect Desktop Editors to a portal is a bug. We added it to our bug tracker and I hope it will be fixed in future versions. Sorry for the inconvenience. For now, it is only possible to work with Mendeley plugin via browser.
