InsertAndReplaceContentControls inline
Serhii
Post by Serhii » Mon Jan 07, 2019 9:56 pm
Hi!
How to replace the existing inline "Content Control" with simple inline text?
The example code from the documentation
window.Asc.plugin.executeMethod('InsertAndReplaceContentControls', [[{
          Props: {
            InternalId: currentCCInternalId
          Script: "var doc = Api.GetDocument(); var p = Api.CreateParagraph(); p.AddText('Hello world!'); doc.InsertContent([p]);"
adds unnecessary line break after "Hello world!", but I need to replace without it.
Re: InsertAndReplaceContentControls inline
Post by Carl » Tue Feb 05, 2019 7:57 am
Try to insert it like this
oDocument.InsertContent([p], true);
