feature request: spreadsheet date filter
lenz
Post by lenz » Tue Dec 22, 2020 4:15 pm
On spreadsheets there is a possibility to use number filter. Unfortunately they don't work well with dates.
Have you plans on adding date filter any time soon or at all ?
I would really appreciate the possibility to display lines within a certain period of time
Thanks for your reply
Serge
Re: feature request: spreadsheet date filter
Post by Serge » Thu Dec 24, 2020 1:03 pm
Thanks for the feedback.
The number filter isn't designed for dates, I'm afraid, but we'll consider adding a dedicated one. For now, you could create a pivot table and use one of the label filters that will allow you to sort dates, to an extent.
