How to set read only docx and xlsx files?
MarcoD
Post by MarcoD » Fri Nov 15, 2019 3:53 am
I installed Document Server and integrate it with NextCloud.
How to change settings OnlyOffice for read only docx and xlsx documents?
I guess that it in api.js settings.
What must i change in api.js?
Andrew
Re: How to set read only docx and xlsx files?
Post by Andrew » Fri Nov 15, 2019 8:31 am
Hello MarcoD,
I am afraid there is no such methods in Document Server API, these permissions should be implemented on the side of documents storage application.
MarcoD
Post by MarcoD » Fri Nov 15, 2019 8:39 am
MarcoD
Post by MarcoD » Fri Nov 15, 2019 12:29 pm
I mean what I need that all docx and xlsx files open in Onlyoffice from NextCloud only for reading, without edit permition.
Andrew
Post by Andrew » Fri Nov 15, 2019 1:17 pm
Document Server executes your configuration and can open files in different modes, you can use this page to try different variants and how it will look for user. I am sorry, but specific code implementation on Nextcloud side is beyond my competence.
MarcoD
Post by MarcoD » Sun Nov 17, 2019 2:35 am
Ok, thanks for reply.
Could I change the default display mode from "MarkUp" to "Final" or "Origanal" to all users?
