Custom plugin does not show up after Docserver update
shippeli
Post by shippeli » Mon Jun 24, 2019 3:09 pm
i've implemented a plugin for the document server. After the last update (5.3.2) of the document server it does not show up in the tabs. I dont know exactly what version of the document server ran before. Last time i saw the plugin working was in the side bar.
Are there new specs for plugins or plugin configuration. I could not find any hints.
Thank you
Re: Custom plugin does not show up after Docserver update
Post by Maxim » Tue Jun 25, 2019 6:50 am
Hello shippeli!
All specs you can find in ONLYOFFICE Document Server Plugins documentation.
As i know we did not change plugin configuration.
