OnlyOffice | Document server | Angular integration issue
vicky25vishal
Post by vicky25vishal » Wed Mar 06, 2019 10:39 am
I am trying to load OnlyOffice editor using Angular 6, But my angular app and document server are on different machines. so when angular app tries to load api.js to load editor its showing CORS issue while loading api.js.
I have attached browser response and console log which expecting 'Access-Control-Allow-Origin' header in response.PFA for screen shots.
Please help me to resolve this issue.
Re: OnlyOffice | Document server | Angular integration issue
Post by Maxim » Wed Mar 06, 2019 11:34 am
What instruction you followed to install Document Server?
Try to add header into /etc/nginx/includes/ onlyoffice-http.conf
add_header 'Access-Control-Allow-Origin' 'localhost:4202';
or
add_header 'Access-Control-Allow-Origin' 'http://localhost:4202';
and restart Document server
vicky25vishal
Post by vicky25vishal » Wed Mar 06, 2019 2:13 pm
Hi Maxim,
I have followed below steps to install it on my system as i am creating POC on it.Its deployed on windows machine.
https://helpcenter.onlyoffice.com/serve ... -apps.aspx
Thanks for the help. The solution you provided it worked for me.
sumesh.tc@gmail.com
Post by sumesh.tc@gmail.com » Wed Jul 24, 2019 5:59 am
How can i integrate only office document editor in my angular app
Post by Maxim » Thu Jul 25, 2019 8:22 am
Hello sumesh.tc@gmail.com!
Please visit our API for the Onlyoffice Document Server
sumesh.tc@gmail.com
Post by sumesh.tc@gmail.com » Fri Jul 26, 2019 10:20 am
I have tried these bu not getting any examples .
uwohlfeil
Post by uwohlfeil » Wed Jul 31, 2019 7:26 am
Hi sumesh.tc@gmail.com,
I also use OnlyOffice in an Angular 6 application. The angular app and the onlyoffice instance are on a different domains.
By angular backend is a spring boot microservice (java).
Your application have to allow your browser to load cross domain code.
https://developer.mozilla.org/en-US/doc ... low-Origin
In Spring boot for example:
protected void configure(HttpSecurity http) throws Exception {
http.cors();
http.csrf().disable();
Best Regards
Ulrich Wohlfeil
sumesh.tc@gmail.com
Post by sumesh.tc@gmail.com » Wed Aug 07, 2019 7:12 am
Thanks for your time ...
