(Spreadsheet) How to delete a table?
mus
Post by mus » Fri Sep 22, 2017 9:09 am
When you select a range of cells and choose "Format as table template", then you get a table. That's understood.
It receives an automatic name and appears in the "Name Manager".
BUT there seems to be no way to delete such a table any mode? Excel has a context menu item "convert to range" for that.
In the Name manager, these automatically names ranges can be renamed, but not deleted or edited in any other way.
why is that? I want to undo a table i accidentally created, but i need to switch to excel to do so.
Re: (Spreadsheet) How to delete a table?
Post by Maxim » Mon Sep 25, 2017 9:21 am
Hello mus!
That's strange! Just now i have tried to reproduce the issue but it's ok! I have deleted via undo.
mus
(SOLVED) (Spreadsheet) How to delete a table?
Post by mus » Wed Sep 27, 2017 3:27 pm
I was wrong! Just couldn't find the "Convert to Range" Feature, (which is in a context menu in Excel) - it's in the Table formatting sidebar. My apologies.
Post by Maxim » Thu Sep 28, 2017 7:58 am
Hello mus!
it's ok!
