Macro Plugin Installation | Docker + Nextcloud
Yonggan
Post by Yonggan » Sun Mar 07, 2021 3:43 pm
Hey,
i have a problem with installation of the Macro Plugin in OnlyOffice in combination with Nextcloud.
The Problem is that the Plugins tab does not appear in onlyoffice when i edit a xlsx file via Nextcloud.
I am using the Docker Image: onlyoffice/documentserver
I have mounted the latest release of the macro plugin into the Docker container at /var/www/onlyoffice/documentserver/sdkjs-plugins
so the plugin lays at /var/www/onlyoffice/documentserver/sdkjs-plugins/macros in the container
I mounted the production-linux.json to the host so i can add the plugin via config.
My config looks now like this:
  "log": {
    "filePath": "/etc/onlyoffice/documentserver/log4js/production.json"
  "storage": {
    "fs": {
      "folderPath": "/var/lib/onlyoffice/documentserver/App_Data/cache/files"
  "services": {
    "CoAuthoring": {
	   "plugins":{
            "uri":"/sdkjs-plugins",
            "autostart":[
               "asc.{E6978D28-0441-4BD7-8346-82FAD68BCA3B}"
      "server": {
        "static_content": {
          "/fonts": {
            "path": "/var/www/onlyoffice/documentserver/fonts",
            "options": {"maxAge": "7d"}
          "/sdkjs": {
            "path": "/var/www/onlyoffice/documentserver/sdkjs",
          "/web-apps": {
            "path": "/var/www/onlyoffice/documentserver/web-apps",
          "/welcome": {
            "path": "/var/www/onlyoffice/documentserver/server/welcome",
          "/info": {
            "path": "/var/www/onlyoffice/documentserver/server/info",
          "/sdkjs-plugins": {
            "path": "/var/www/onlyoffice/documentserver/sdkjs-plugins",
      "utils": {
        "utils_common_fontdir": "/usr/share/fonts"
      "sockjs": {
        "sockjs_url": "/web-apps/vendor/sockjs/sockjs.min.js"
  "license": {
    "license_file": "/var/www/onlyoffice/documentserver/../Data/license.lic",
    "warning_limit_percents": 70,
    "packageType": 0
  "FileConverter": {
    "converter": {
      "fontDir": "/usr/share/fonts",
      "presentationThemesDir": "/var/www/onlyoffice/documentserver/sdkjs/slide/themes",
      "x2tPath": "/var/www/onlyoffice/documentserver/server/FileConverter/bin/x2t",
      "docbuilderPath": "/var/www/onlyoffice/documentserver/server/FileConverter/bin/docbuilder",
      "docbuilderAllFontsPath": "/var/lib/onlyoffice/documentserver/App_Data/docbuilder/AllFonts.js"
  "FileStorage": {
    "directory": "/var/lib/onlyoffice/documentserver/App_Data"
  "SpellChecker": {
    "server": {
      "dictDir": "/var/www/onlyoffice/documentserver/server/SpellChecker/dictionaries"
I can access the plugin config.json in the browser.
The sdkjs-plugins folder belongs to the ds user and has 755 Permission.
In the logs does not stand anything about loading a plugin or something (err.log is empty):
[2021-03-07T15:29:29.524] [WARN] nodeJS - Express server listening on port 8000 in production-linux mode. Version: 6.2.0. Build: 123
[2021-03-07T15:30:28.092] [WARN] nodeJS - Express server starting...
[2021-03-07T15:30:28.095] [WARN] nodeJS - Failed to subscribe to plugin folder updates. When changing the list of plugins, you must restart the server. https://nodejs.org/docs/latest/api/fs.html#fs_availability
[2021-03-07T15:30:28.218] [WARN] nodeJS - Express server listening on port 8000 in production-linux mode. Version: 6.2.0. Build: 123
I now have spent 8 hours just trying to get this plugin installed im really struggling here.
It would be nice if somebody could help me.
psanf
Re: Macro Plugin Installation | Docker + Nextcloud
Post by psanf » Sat Mar 13, 2021 2:22 pm
Hi!
I have exactly the same problem, and searching for hours without success.
Did anyone here found a solution?
Thanks a lot,
Pierre.
Post by Carl » Mon Mar 15, 2021 1:12 pm
Hello Yonggan & psanf,
Please try installing the Document Server without mounting the plugin folder. I cannot reproduce the issue this way as the Plugin tab appears in the spreadsheet editor by default and Macros are available there.
Yonggan
Post by Yonggan » Wed Mar 17, 2021 7:03 am
I allready tried without mounting Plugins Folder but the Plugins Tab doesn´t appears either.
Yonggan
Post by Yonggan » Wed Mar 17, 2021 3:19 pm
Doesn´t work either.
The Tab is also not there without mounted plugins folder
Post by Carl » Mon Mar 22, 2021 2:09 pm
Hello Yonggan,
We have reproduced the issue. It is a bug that will be fixed in the upcoming hotfix version 6.2.1 of the Document Server (to be released in 1-2 weeks). Sorry for the inconvenience.
As a workaround, you can use the previous Document Server version 6.1.1, Plugin tab is displayed correctly there.
