Document Server cannot connect public IP
longld
Post by longld » Thu Dec 12, 2019 5:14 am
I've installed the Document Server on a Windows Server 2016. Everything works great in local address, but i cannot connect via public IP address:
Please see in attachment
Any idea ?
Thanks
Andrew
Re: Document Server cannot connect public IP
Post by Andrew » Thu Dec 12, 2019 9:16 am
Hello longld,
It could be routing problems or firewall may block your connection, please check firewall settings. Do you have a static public ip address on this machine without NAT or proxy? If your network configuration uses NAT please check port forwarding rules for external/internal networks.
longld
Post by longld » Fri Dec 13, 2019 4:18 pm
Thanks for respond, Andrew,
I have google cloud VPS for test:
35.223.191.106
User remote: longld
Password: ,(!\N2L_?0ZfGmN
I'm beginner for network config, can you help me config example for window server 2012 ?
I install success:
Thank you so much
Post by Carl » Mon Dec 16, 2019 11:08 am
Hello longld,
If you see the Welcome page of the Document Server, it means it is functioning correctly. Inability to access it via external IP must be fixed on your network level. I'm afraid we cannot give any advice on that.
