(Community Server) Failing Clean Install - Ubuntu 16.04
AndySputnik
Post by AndySputnik » Wed Aug 22, 2018 12:00 pm
Hi all,
I'm having some problems installing on a clean Ubuntu 16.04 server. I've done this fine in the past with no problem so I'm probably missing something really stupid. Hoping you guys can spot it for me.
I can get all the way to the post install wizard, however:
  • - After filling in the form I get the notification 'Unauthorised Request'.
    - Attempting to try again presents the message 'Wizard Passed'.
    - I do receive the welcome email
    - Trying the address again goes to the login screen
    - Login fails
    - I can successfully reset the password
    - Login still fails
Command history with a few comments:
  • ###### Post install configure static IP and update apt packages
    sudo nano /etc/network/interfaces
    sudo ip addr flush ens32
    sudo service networking restart
    sudo apt-get update
    sudo apt-get upgrade
    ###### Begin OnlyOffice install
    ## Mono-complete
    sudo apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys 3FA7E0328081BFF6A14DA29AA6A19B38D3D831EF
    sudo apt install apt-transport-https
    echo "deb https://download.mono-project.com/repo/ubuntu stable-xenial main" | sudo tee /etc/apt/sources.list.d/mono-official-stable.list
    sudo apt update
    sudo apt-get install mono-complete
    ## NodeJS
    curl -sL https://deb.nodesource.com/setup_10.x | sudo -E bash -
    sudo apt-get install -y nodejs
    ## OnlyOffice
    sudo apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys CB2DE8E5
    sudo echo "deb http://download.onlyoffice.com/repo/debian squeeze main" | sudo tee /etc/apt/sources.list.d/onlyoffice.list
    sudo apt-get update
    sudo apt-get install onlyoffice-communityserver
    ## For purposes of testing, the mysql password used when requested was 'onlyoffice'
AndySputnik
Re: (Community Server) Failing Clean Install - Ubuntu 16.04
Post by AndySputnik » Thu Aug 23, 2018 11:57 am
Resolved.... kinda...
After many many hours of backwards and forwards, i eventually tracked the issue back to a domain name issue, although I can't fathom for the life of me how or why this was a thing...
- Originally, Ubuntu was configured as office.xxxxxxxxxxxxx.co.uk (dns also pointed to that server's IP) ... see my original issue
Eventually rebuilding Ubuntu again without the fqdn (I used a random name), I was able to successfully log in to OnlyOffice. However after this, I would go into settings and set the custom domain to office.xxxxxxxxxxxxx.co.uk , and this would result in me being able to reach the web login page at office.xxxxxxxxxxxxx.co.uk ,but with all login attempts just failing completely.
The eventual resolution, was to use a different subdomain... I ended up using work.xxxxxxxxxxxxx.co.uk , and that worked perfectly first time.
I have absolutely what was going on in this situation. The domain name was resolving back with nslookup perfectly on all systems. I'm at a loss.
