Apache2 vs NGINX - Servers's conflict
Otaner
Post by Otaner » Mon Jul 09, 2018 2:14 pm
Hi all,
I'm trying to install the document server for Onlyoffice and I've had some difficulties with servers's configuration.
The Apache server is configured to port 80 (I can't change this port) and when I install the nignx server, it's configured as default to the same port. I search about this issue and to change this definition is necessary to edit the file named /etc/nginx/sites-available/default
server {
listen 3200 default_server;
There I changed the number of the port from 80 to 3200 but after this modification the problem keep it. The conflict between Apache2 and Nginx wasn't solved and I can't keep this to services started at the same time.
Could anyone help me with this issue? How can I change definitely the port of nginx's server?
PS: My OS is Debian 9.4
Re: Apache2 vs NGINX - Servers's conflict
Post by Maxim » Tue Aug 06, 2019 8:30 pm
Hello Otaner!
Have you found a solution?
Normaacimb
Apache2 vs NGINX Serverss conflict
Post by Normaacimb » Sun Aug 18, 2019 12:37 pm
Ich kenne Nginx so gut wie nicht. Ich kenne Apache aber /- doch so, dass es für produktive Umgebungen reicht. Daher der Vorzug an Apache. Aber ich denke es kommt ganz auf den Einsatzzewck drauf an, ob die eingesetze Webanwendung supportet ist, ob die Distribution den Webserver im Repository hat, etc.
Image ;-)
