Uploading Documents Fails
ThinkPrivacy
Post by ThinkPrivacy » Mon May 25, 2015 2:27 pm
When I attempt to upload a document for a project, I get the following error:
Mixed Content: The page at 'https://mydomain.com/products/projects/ ... ?prjID=2#7' was loaded over HTTPS, but requested an insecure XMLHttpRequest endpoint 'http://mydomain.com/products/files/Chun ... f63d2ff4f5'. This request has been blocked; the content must be served over HTTPS.
send @ oKim7CqjEHleoSHzushXTw2.js:2
Any ideas how I can fix this please?
ThinkPrivacy
Re: Uploading Documents Fails
Post by ThinkPrivacy » Mon May 25, 2015 11:26 pm
OK this only happens if I press the upload button next to "CREATE" drop down list. If I attach a file from the task page, it uploads no problem.
User avatar
Post by AnaMih » Tue May 26, 2015 12:41 pm
Please, specify how onlyoffice community server was installed? Did you follow this instruction? especially step 3 in "Installing ONLYOFFICE Community Server integrated with Document and Mail Servers" section and section "Running ONLYOFFICE Community Server using HTTPS".
Pay attention to the programs installation sequence:
1) Installing ONLYOFFICE Document Server.
2) Installing ONLYOFFICE Mail Server.
3) Installing ONLYOFFICE Community Server.
ThinkPrivacy
Post by ThinkPrivacy » Tue May 26, 2015 7:15 pm
Yes I followed the guide to the letter.
jonzobot
Post by jonzobot » Sat May 30, 2015 4:25 pm
I am having this same problem. I am only testing out the server on localhost. When I click the "Upload" button on the Documents panel, I get a generic "Error" without more. However, I am able to upload using the Tasks panel like the poster above. I also installed using the same guide.
User avatar
Post by AnaMih » Mon Jun 01, 2015 1:01 pm
to ThinkPrivacy:
Did you try restarting the monoserve? The downloading starts through http
Please, specify the certificate type (self-signed certificate?)
to jonzobot:
1) Check the domain name in the console (f12) after the request api/2.0/files/38/upload/create_session.json
Try opening the portal using this domain name
2) Check if there are the following lines in web.config (путь). If there are not, please, add these lines.
<system.webServer>
<httpProtocol>
<customHeaders>
<add name="Access-Control-Allow-Origin" value="*"/>
<add name="Access-Control-Allow-Headers" value="Content-Type, Content-Range, Content-Disposition, Content-Description"/>
</customHeaders>
</httpProtocol>
rmx
Post by rmx » Mon Dec 11, 2017 10:57 pm
Hello, got the same problem, and a long way to find a working solution...
So I installed OnlyOffice the Docker way, with the network bridge, mysql, DocumentServer and CommunityServer with mapped port: -p 8001:80 -p 8003:443 -p 8004:5222.
So the CommunityServer listens to the HTTP interface on the (internal) port 8001, and I've set up nginx as reverse proxy with a SSL certificate that proxy the communication to the CommunityServer, and here is the nginx vhost fix that bypass the ChunedUplader mixed-content bug:
server {
	listen 443 ssl http2;
	server_name YOUR_ONLYOFFICE_DOMAIN;
	ssl_certificate ssl/YOUR_ONLYOFFICE_DOMAIN_CERT.pem;
	ssl_certificate_key ssl/YOUR_ONLYOFFICE_DOMAIN_CERT.key;
	location / {
		# Fix OnlyOffice mixed content problem with ChunkedUploader
		add_header Content-Security-Policy upgrade-insecure-requests always;
		add_header "Access-Control-Allow-Origin" "*" always;
		add_header "Access-Control-Allow-Methods" "POST, GET, OPTIONS" always;
		add_header "Access-Control-Allow-Headers" "Content-Type, Accept, Authorization, Origin" always;
		proxy_hide_header Access-Control-Allow-Origin;
		if ($request_method = "OPTIONS") {
			return 204;
		# Allow WebSockets to work...
		proxy_http_version 1.1;
		#proxy_set_header Connection $connection_upgrade; # /etc/nginx/maps/connection_upgrade.conf
		proxy_set_header Connection "upgrade";
		proxy_set_header X-Forwarded-Host $host;
		proxy_set_header X-Forwarded-Server $host;
		proxy_set_header Host $host;
		proxy_pass http://127.0.0.1:8001$request_uri;
So it's this part that does the trick:
			return 204;
Hope this will hep you :)
