Another documentbuilder question
hanland
Post by hanland » Tue Sep 10, 2019 4:17 pm
I am trying to read and update the contents of a document table cell. There is no obviously documented API for this. I can get the cell content and have tried using this or the first element of the content which identifies itself via GetClassType as "paragraph". How can I read the "string" value of the content???
Regards
Andrew
Re: Another documentbuilder question
Post by Andrew » Thu Sep 12, 2019 8:22 am
Hello hanland,
You can use GetValue for it, it is actually getter and we will fix it in documentation. Here is examples for you:
https://github.com/ONLYOFFICE/doc-build ... t_value.js
https://github.com/ONLYOFFICE/doc-build ... r_value.js
hanland
Post by hanland » Thu Sep 12, 2019 11:24 am
Thanks for the reply but this is for a docx document, does the same GetValue exist there?
Also can I access document custom properties with the docx API?
Do I need a specific version of documentserver to access the mailmerge functionality, currently grayed out in the CE version downloaded last week, or is this configure via the documentApi DocsAPI.DocEditor config??
Regards
