System.Configuration.ConfigurationErrorsException
BranKo
Post by BranKo » Thu Sep 05, 2019 12:28 pm
Hello I got this error.
Description: HTTP 500.Error processing request.
Details: Non-web exception. Exception origin (name of application or object): ASC.Core.Common.
Exception stack trace:
at ASC.Core.CoreContext.ConfigureCoreContextByDefault () [0x00018] in <f2ebb25c619f499794aa6983ad0ce1be>:0
at ASC.Core.CoreContext..cctor () [0x00000] in <f2ebb25c619f499794aa6983ad0ce1be>:0
My installation is on Ubuntu Bionic (without docker). It rarely used.
I try to do update but error is still there. I don't know exact failure before update because I add web.config (with customerrors off) after update/reboot.
System was working normally (a month ago)...
Re: System.Configuration.ConfigurationErrorsException
Post by Carl » Thu Sep 12, 2019 7:42 am
Has this error appeared after the update installation? What version of Community Server are you currently using? How did you perform the update? Where and after what action do you see this error?
