Open Local File on document server
sabrehagen
Post by sabrehagen » Mon Aug 12, 2019 7:29 am
When using the desktop apps there is an option to "Open Local File".
How can I enable the "Open Local File" option for editors served from the Document Server? The files to open are located on the hard disk of the Document Server.
Re: Open Local File on document server
Post by Carl » Wed Aug 14, 2019 11:51 am
Document Server cannot open local files. Files must be available via url: https://api.onlyoffice.com/editors/config/document#url
